I get this warning in Batch model EDEM: "WARNING : Deprecated Solver : The OpenCL solver has been deprecated in EDEM 2022.2 and will be removed"
Mahdi_22303
Mahdi_22303 Altair Community Member
edited September 2023 in Community Q&A
Hi,
I am using GPU for a batch mode processing of the EDEM simulation on HPC with Linux system.  When I am using the GUI, I can see that both CUDA and OpenCL are in the options for GPU, and I can select CUDA. First, I am using EDEM 2022.3, so is it using CUDA? if it is still using OpenCL, does it affect the speed of simulations using GPU? if so, is there any syntax I can use to ask EDEM to use CUDA. I am using this syntax
edem -c -i EDEM_project.dem -r 25 -E 1 --rewind
Thank you,
Mahdi.
Welcome!
Best Answer
  • Stephen Cole
    Stephen Cole
    Altair Employee
    edited September 2023 Answer ✓
    And when I use this syntax
    edem -c -i EDEM_project.dem -r 25 -E 2 --rewind
    I get this error message
    ERROR   : Multi-Sphere GPU CUDA Solver : No GPU device is set.
                                      You can perform GPU device testing in Options -> Simulator Engine -> Start test
    How can I avoid this testing stage without needing to open the EDEM in GUI mode?
    Thank you,
    Mahdi.
    Hi Mahdi,
    You can add in -D flag for device.
    edem -c -i EDEM_project.dem -r 25 -E 2 -D 0 --rewind
    This will run on CUDA using 1 GPU and the first GPU device in the list. If you have 4 GPU's they would be device 0, 1, 2 or 3 and you could specify -D 1 or -D 3 etc. if you just wanted to run 1.
    If you want to run on 2 GPU's you can use:
    edem -c -i EDEM_project.dem -r 25 -E 2 -D 0+1 --rewind
    Or -D 1+2, -D 0+3 etc.  And for 4 GPU's it would be -D 0+1+2+3
    Regards
    Stephen
Answers
  • Stephen Cole
    Stephen Cole
    Altair Employee
    Hi Mahdi,
    You can change flag -E 1 to -E 2.  Engine 1 is the OpenCL solver and Engine 2 is the CUDA solver.
    How to use EDEM Batch Commands
    Regards
    Stephen
  • Mahdi_22303
    Hi Mahdi,
    Regards
    Stephen
    Hi Stephen,
    Thank you for your reply. I thought " E 2" in the batch command means using 2 GPUs. If 2 refers to CUDA, then how can we specify number of GPUs to be used. I am requesting in the bash file the number of GPUS using
    #SBATCH --gpus=a100:2  # Request 2 full a100 GPUs for job
    so, then when I am using this command:
    does this mean that EDEM will use both of GPUs?
    Thank you.
  • Mahdi_22303
    Thank you,
    Mahdi.
  • Stephen Cole
    Stephen Cole
    Altair Employee
    Thank you,
    Mahdi.
    Hi Mahdi,
    Regards
    Stephen
  • Mahdi_22303
    Hi Mahdi,
    Regards
    Stephen
    Thank you so much Stephen, it worked.
Welcome!
Welcome!
