I am using GPU for a batch mode processing of the EDEM simulation on HPC with Linux system. When I am using the GUI, I can see that both CUDA and OpenCL are in the options for GPU, and I can select CUDA. First, I am using EDEM 2022.3, so is it using CUDA? if it is still using OpenCL, does it affect the speed of simulations using GPU? if so, is there any syntax I can use to ask EDEM to use CUDA. I am using this syntax
edem -c -i EDEM_project.dem -r 25 -E 1 --rewind
Thank you,
Mahdi.
