Hypermesh: Modal analysis with enforced displacement (acceleration/frequency) at SPC point
Hi everone,
I'm trying to do a Freq. resp (modal) with an acceleration input (Acc/frequency) at the fix point of my model (node ID 10) but I find in the H3D result no displacement...
I used this can of cards:
- SPC (node 10) with all DOF checked = 0.0
- SPCD (node 10) with just DOF 2 (Y axis for me) checked = 1.0
- DAERA (node 10) with just DOF 2 (Y axis for me) checked = 1.0
I have a a RLOAD2 for my DAERA with a curve in TABLED1.
My definition in the attachments.
Thx!
Regards,
Axel
DAREA is need only for FORCE input, and it should NOT be used with SPC.
In your case, SPCD+SPC is the correct setup, pointint the SPCD into the RLOAD2, set to acceleration.
remove the DAREA.
