🎉Community Raffle - Win $25
Join and Win
[SOLVED] Using Loop Parameters for general purposes
tennenrishinUser: "tennenrishin"
New Altair Community Member
Updated by Jocelyn
What is the easiest way to silence this warning message?:
"Inner operators of Loop Parameters do not provide performance vectors. Performance cannot be plotted."
In my use cases it usually dilutes other more important messages in the log.
1 - 2 of 21
    Hi,
    currently, there is no parameter to get rid of the warnings. There are at least 2 workarounds though:
    - increase the log level of the main process to "warning". That will limit the log output to actual warnings (meaning that maybe also some other important messages will be omitted).
    - create some dummy performance and connect it to the performance output of Loop Parameters. That could be e.g. the number of examples in an example set, since that is reasonable fast to calculate. Use Extract Performance for that.
    In any case, I will create an internal issue requesting to remove that warning.
    Best regards,
    Marius
    Thank you.
