🎉Community Raffle - Win $25
Join and Win
RapidMiner locks up on startup
User: "dxfolder"
New Altair Community Member
Updated by Jocelyn
I had to uinstall and move rapid miner 5.2 to a new install spot, and i didn't want to keep the repositories.  I did the uninstall, removed the original directory, then re-installed in a new location.  Now will start, but will not respond to any clicks when i say create new repository.  The only way i can get it to close is clicking the window close X, after which RM puts up a blank dialog box, and will close if i click where the OK button should be.  Or if i start with console, just close console.  The console doesn't say anything interesting, except complaining about some jdbc drivers and the xml file not having a password.
Please help!  I am completely stuck!
Thank you
1 - 1 of 11
    User: "Nils_Woehler"
    Hi,
    try to remove the .RapidMiner5 folder that should be located in your user folder. Then start RapidMiner. Hopefully this helps.
    Best,
    Nils
