Mistake in OperatorDocLoader.loadSelectedOperatorDocuLocally?
I've been looking into how RapidMiner defines operator documentation bundles in XML (resources/com/rapidminer/resources/i18n/OperatorsCoreDocumentation.xml) but then substitutes html in the GUI's help window. For instance, the stream_database operator's XML doc bundle (an element of OperatorsCoreDocumentation.xml) is not used: rather, RapidMiner substitutes /resources/com/rapidminer/resources/doc/core/stream_database.html
This is not hinted at anywhere within the operator documentation; there is nothing in the operator's description XML that links it to the html documentation (unlike the xml documentation, which is explicitly identified in the extension's OperatorsSHORTNAME.xml, 'operators' element, 'docbundle' attribute). It took me a while to find that it happens in OperatorDocLoader.loadSelectedOperatorDocuLocally, which (if online) first looks for a page on the RapidMiner wiki, and then falls back to an html file. Only if this also fails is the XML doc bunde actually used.
Fine, I'm now ready to write an html page similar to those describing the core operators and include it in my operator plugin...But loadSelectedOperatorDocuLocally constructs the name like this:
com/rapidminer/resources/doc/NAMESPACE/SHORTNAME:NAME.html
...which is not a legal file name under most file systems because of the colon (highlighted in red in the line above). The culprit is line 496:
String documentationResource = "/" + RESOURCE_SUB_DIR + "/" + namespace + "/" + opDesc.getKey() + ".html"
I have a feeling it should instead be:
String documentationResource = "/" + RESOURCE_SUB_DIR + "/" + namespace + "/" + opDesc.getKeyWithoutPrefix() + ".html"
Am I right?
(Note also how the 'key' used here is NOT the 'key' defined in the operator's XML description: it is instead the 'shortName' element prefixed to the 'name' element (with substitution of underscores for spaces); this is a little confusing)
Am I right?
