Altair RISE
Nominate Yourself Now!
Creating a very basic 2D mesh
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi Guys,
I'm a very new user to HyperMesh and I'm looking to do a very basic 2D topology optimization on a rectangular structure with one force on it. I want to create a PSHELL geometry and use a 4mm x 4mm mesh size. So far i used geometry>create nodes and then geometry>create lines to get the outline of the geometry, but I haven't been able to figure out how i should go about making the elements. Any help would be greatly appreciated.
1 - 4 of 41
    User: "Sanjay Nainani_20973"
    New Altair Community Member
    Updated by Sanjay Nainani_20973
    Hello,
    After creating the lines create surfaces. Then go to AutoMesh panel in 2D>>Automesh and give the mesh size and create the elements.
    As you are a new user i would suggest you to go through our free eBooks  https://altairuniversity.com/free-ebooks-2/
    Also go through our Learning & Certification Program https://certification.altairuniversity.com/
    Thankyou
    Altair Employee
    OP
    Hello,
    Thankyou
    Thank you for your help, I seem to have the mesh working now, there was just one thing I am unsure of. I need to make the 2D geometry with PSHELL with a thickness of 3mm. Should I have done this before I made the mesh? Currently my mesh has no thickness I believe.
    Would I do this by creating a property collector with a PSHELL card image and then settting the thickness there?
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    When you have defined PSHELL card, you do 'assign' by right clicking on component:
    Choose the PSHELL card and 'Apply':
    2
    Hello @pleace,
    Yes you need to create a property collector and assign the thickness to that property.
    Then you have to assign this property to the component.
    You also need to create and assign a material to the component.
    Thank you
