Altair RISE
Nominate Yourself Now!
"How to Setup Value Series Feature Extraction Operator with Windowing Operator"
User: "samup4web"
New Altair Community Member
Updated by Jocelyn
Hi all,
I trying to use Series Extension to perform classification on multivariate time series data. So far, I have been able get sliding window using the 'Windowing" operator (encode series by examples)
Example of source data:
point1      point2      point3    label
a1            b1            c1        class1
a2            b2            c2        class1
a3            b3            c3        class1
Since I wish to perform classification on these data points. I intend to extract features based on the sliding window and then have dataset similar to the example below (assume window size=2)
Point1-1  Point1-0        Point1-Extracted-Feat.      Point2-1      Point2-0        Point2-Extracted-Feat.    Point3-1        Point3-0      Point3-Extracted-Feat          label
a1            a2                    XXXXXX                          b1                  b2                    XXXXXXX                      c1                  c2                        XXXXXXXX              Class1
a3            a4                    XXXXXX                          b3                  b4                    XXXXXXX                      c3                  c4                        XXXXXXX                Class1
With this approach, I can select the extracted features as attributes for the classification process.
So far, I have only been able to get the attributes (Point1-1, Point1-0, Point2-1, Point2-0, Point3-1, Point3-0) using the window operator. But when I attempt to use the operators such as Discrete Wavelet Transformation, it only operated on the first example (i.e a1, a2, b1, b2, c1,c2). I also had to use the "Data to Series"Operator to be able to use any of the extraction or transformation operator for series. I don't know if I am using the write approach.
What is the best setup for this approach?
What is the best setup for using sliding window and extracting features to give a similar dataset similar to the example I showed above.
Best Regards
/Sam
