Altair RISE
Nominate Yourself Now!
How to avoid negative jacobians while morphing
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello guys,
I want to morph a model but after moving my handles there are always some negative jacobians/folded elements. Also after a small movement (about 1-2mm) there are some folded elements (sometimes only 2 folded elements). The size of my model is around 150mm * 250mm and the element size in the moprhing region is around 0.5mm - 5mm.
Is there any options to avoid folded elements? Maybe meshing with smaller elements or bigger elements or try some various options in the 'morph' subpanel?
It would be great if anybody can help me!
1 - 4 of 41
    Altair Employee
    OP
    Hi,
    Please go through the tutorial HM-3690: Remeshing Domains After Morphing, which shows updating the mesh in regions that might have undergone excessive elemental deformation during morphing.
    Altair Employee
    OP
    Ok, thanks!
    I had this thought already to remesh the critical regions. My objective is to do an optimization with the morphed mesh in HyperStudy.
    I don't know if I can reach my objective after remeshing but I will try.
    Altair Employee
    OP
    I tried to remesh like in the tutorial HM-3690 but I got an error that the element angles exceed the tolerance.
    Has anybody an idea what to do now? Should I smooth the mesh before remeshing or are there any other options?
    Altair Employee
    OP
    Hi,
    I think this is because of improper movement of handles/nodes. You can try by choosing the fixed nodes and appropriate nodes to move so that the elements are not destroyed.
    Please go through Morphing in the Help Menu where all these options are explained.
