[Solved]Process Document from Data
Hi ,
I am retrieving data from DB having column as ID ,TEXT
but when I provide data to Process Document from Data operator , it gives me Row No TEXT and different word counts as columns .
I need ID column as well , so that I can update the database for the same IDs .
Please let me know how to maintain ID column as attribute through out the process.
Regard,
Ankit
Regard,
Ankit
1 - 4 of
41
Thanks for your reply.
I am reading from a database having id column using Read Database operator, applying o/p of this to SET Role Operator and then output of role operator is applied to Process document in which tokenizing, stemming, filterting and n gram generation are performed.
Still not getting ID column at the output of process document.
Regards,
Ankit
Regards,
Ankit
adding a Set Role operator before process documents and assigning the id role to the ID attribute should do the job.
Best,
Marius
