No, as far as I know this functionality is not yet implemented, at least not in the sense that you can directly retrieve the numbers. However, for the quantiles maybe the Discretize by Frequency operator can help you.
Thanks. Anyway, the R plug-in can also be used to compute these statistics in RapidMiner. I use R separately for both Stats and Data Mining, but I was not sure if the integration of R 64 bit in RapidMiner 64 bit works well.
I do not have the R extension in regular use myself, but I have it installed and ran a few test processes - everything worked fine so far. Admittedly, the installation process of R needs some love, but as I said, in general it works.
Best, Marius
