Activate vs Modelica bus conversion? (for Include block)
Hi everyone!
Wondering if anyone might have an idea about converting Activate bus to Modelica bus, this one might be a little tricky.
I want to use the very nice "IncludeDiagram" block in Activate, but I also want to use *both* Modelica and Signal input/outputs for the Include block; currently there is only either all Modelica (IncludeDiagramComponent) or all Signal (IncludeDiagram). For the signal output I want to use a bus. For the Modelica inputs/outputs I use electrical and thermal domain.
So, I wonder if I can use a a IncludeDiagramComponent and then convert an Activate bus to a Modelica bus (e.g. structureField to interface). I've been playing around, I haven't figured out a way to do this yet, wondering if anyone has an example that works.
Thanks,
Andy
