Select attributes subset doesn't showing attributes
New Altair Community Member
Updated by Jocelyn
It won't shows attributes for selecting in subset, after Rapidminer crashed. On other machine 64bit version works fine. I tried to uninstalled and installed without restarting, but the problem didn't solved.
1 - 6 of
61
Aj
Try putting a break point before execution of the that select attributes elements. Then, different variables will show up at that break point, and you can select the subset of attributes. You can save it and remove the breakpoint.
I do not know why select attributes element does not show attributes in some cases - it usually happens if that element is deep inside the program flow. Following is the procedure for attributes to appear in select attributes elements, if such a thing happens
1) Put a break point by right clicking on the select attributes element, such that the program stops before execute that element
2) Run the program
3) Program will stop at the break point and show you the attributes that you can select. Select attributes you want to, save the program and start it again.
2) Run the program
