<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process"> <process expanded="true" height="251" width="413"> <operator activated="true" class="generate_data_user_specification" compatibility="5.3.000" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="112" y="120"> <list key="attribute_values"> <parameter key="time" value="1348820137"/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.3.000" expanded="true" height="76" name="Generate Attributes" width="90" x="313" y="120"> <list key="function_descriptions"> <parameter key="time" value="date_parse(time)"/> </list> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
you can convert it with Generate Attributes and parse Date. Best,
Nils
