Using msolve API
Hi all,
I want to use msolve api in Pyhton. But, I didn't define msolve library correctly.
At first, When I tried use msolve library, I got the following error message.
I found the msolve library on this file path 'C:\Program Files\Altair\2020\hwsolvers\motionsolve\msolve' and copy to this path 'C:\Program Files\Anaconda3\Lib'. I solved this problem, but I got the new error message. You can see below.
How can I define ms_modelapi35 and run correctly msolve api ?
Thanks for the replies.
