🎉Community Raffle - Win $25
Join and Win
[SOLVED] generate nominal attributes?
kersorUser: "kersor"
New Altair Community Member
Updated by Jocelyn
hello
an  with the generate attributes operator to reate nominal attributes if a statement is true?
somithing like this: if(att_1<0 ,"Positive"),
I tried it and has an error.Do you know any other way?
1 - 2 of 21
    You are forgetting the "else" part of the "if" command.
    Example. att6 = "Positive" if att1 > 0 Else "Negative"
    Check out the following code:
    <?xml version="1.0" encoding="UTF-8" standalone="no"?>
    <process version="5.2.006">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process">
        <process expanded="true" height="-20" width="-50">
          <operator activated="true" class="generate_data" compatibility="5.2.006" expanded="true" height="60" name="Generate Data" width="90" x="67" y="54"/>
          <operator activated="true" class="generate_attributes" compatibility="5.2.006" expanded="true" height="76" name="Generate Attributes" width="90" x="232" y="54">
            <list key="function_descriptions">
              <parameter key="att6" value="if(att1&gt;0,&quot;Positive&quot;,&quot;Negative&quot;)"/>
            </list>
          </operator>
          <connect from_op="Generate Data" from_port="output" to_op="Generate Attributes" to_port="example set input"/>
          <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/>
        </process>
      </operator>
    </process>
    OP
    Yes you are right!!!!!
    Thanks a lot!!!!!! 8)
