Methods of exporting eddy current density distributions.
I am using CAD FEKO version 2022.1.1
How can I export the distribution of the eddy current density generated in the heated object when a current is applied to the coil?
The model is used with the heated object in the centre of the coil, as shown in this image.
Thank you for your interest in this post.
You can select the following two methods to export the current distribution.
1) When requesting Currents in CADFEKO, you can enable Export current to ASCII files (as shown below)
This method allows you to get the ASCII file right after the simulation is done and is available in the simulation directory.
2) When the export current is not selected during model creation in CADFEKO (method 1), the current distribution can still be exported in POSTFEKO (Home tab> Export, as shown below)
Hope this helps.
Thank you for your response.
I was able to export the eddy current density of the coordinate distribution.
Thank you again.
Hope this helps.
Hope this helps.
