Problem with Naive-Bayes [SOLVED]
Hi,
I am using the operator "Naive Bayes" and shows me the following error:
"the learning scheme Naive Bayes does not have sufficient capabilities for handling an example set with only one label.
There are existing special modeling operators if only examples for one class are know. They support the "one class label" capability"
Anyone can explain me better referred to the error?
Thanks.
Thanks.
1 - 6 of
61
ok, here is the xml process...
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.2.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.000" expanded="true" name="Process">
<process expanded="true" height="235" width="480">
<operator activated="true" class="text:process_document_from_file" compatibility="5.2.001" expanded="true" height="76" name="Process Documents from Files" width="90" x="45" y="30">
<list key="text_directories">
<parameter key="positivos" value="C:\Users\yop\Desktop\archivos de tesis\comentarios positivos"/>
<parameter key="negativos" value="C:\Users\yop\Desktop\archivos de tesis\comentarios negativos"/>
</list>
<parameter key="encoding" value="UTF-8"/>
<parameter key="vector_creation" value="Term Frequency"/>
<process expanded="true" height="352" width="586">
<operator activated="true" class="text:transform_cases" compatibility="5.2.001" expanded="true" height="60" name="Transform Cases" width="90" x="45" y="75"/>
<operator activated="true" class="text:tokenize" compatibility="5.2.001" expanded="true" height="60" name="Tokenize" width="90" x="179" y="75"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.2.001" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="313" y="75"/>
<operator activated="true" class="text:stem_snowball" compatibility="5.2.001" expanded="true" height="60" name="Stem (Snowball)" width="90" x="447" y="75">
<parameter key="language" value="Spanish"/>
</operator>
<connect from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Stem (Snowball)" to_port="document"/>
<connect from_op="Stem (Snowball)" from_port="document" to_port="document 1"/>
<portSpacing port="source_document" spacing="0"/>
<portSpacing port="sink_document 1" spacing="0"/>
<portSpacing port="sink_document 2" spacing="0"/>
</process>
</operator>
<operator activated="true" class="x_validation" compatibility="5.2.000" expanded="true" height="130" name="Validation" width="90" x="179" y="30">
<parameter key="number_of_validations" value="2"/>
<process expanded="true" height="352" width="268">
<operator activated="true" class="naive_bayes" compatibility="5.2.000" expanded="true" height="76" name="Naive Bayes" width="90" x="99" y="59">
<parameter key="laplace_correction" value="false"/>
</operator>
<connect from_port="training" to_op="Naive Bayes" to_port="training set"/>
<connect from_op="Naive Bayes" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
<portSpacing port="sink_model" spacing="0"/>
<portSpacing port="sink_through 1" spacing="0"/>
</process>
<process expanded="true" height="352" width="279">
<operator activated="true" class="apply_model" compatibility="5.2.000" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
</operator>
<operator activated="true" class="performance" compatibility="5.2.000" expanded="true" height="76" name="Performance" width="90" x="112" y="165"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="source_model" spacing="0"/>
<portSpacing port="source_test set" spacing="0"/>
<portSpacing port="source_through 1" spacing="0"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
<portSpacing port="sink_averagable 3" spacing="0"/>
</process>
</operator>
<operator activated="true" class="write_model" compatibility="5.2.000" expanded="true" height="60" name="Write Model" width="90" x="380" y="165">
<parameter key="model_file" value="C:\Users\yop\Desktop\archivos de tesis\model\model"/>
</operator>
<connect from_op="Process Documents from Files" from_port="example set" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="model" to_op="Write Model" to_port="input"/>
<connect from_op="Validation" from_port="training" to_port="result 1"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 2"/>
<connect from_op="Validation" from_port="averagable 2" to_port="result 3"/>
<portSpacing port="sink_result 3" spacing="0"/>
<portSpacing port="sink_result 4" spacing="0"/>
</process>
</operator>
</process>
Hm, that looks fine. Is it possible that you have a type in one of the input paths, such that the example set contains only positives or only negatives? You can check that e.g. by setting a breakpoint after process documents and checking the values of the label attribute.
Problems could also occur if your data contains only *very* few examples for one or both of the classes.
Best, Marius
Best, Marius
Naive Bayes is trained on training data which must contain examples for each class. So if you want to create a Naive Bayes model to separate positive and negative examples, your training data must contain both examples with positive and negative label. If your data contains for example only positive examples, you get the error that you quoted.
Best, Marius
