🎉Community Raffle - Win $25
Join and Win
[SOLVED] IOObjectCollection to ExampleSet conversion
User: "zis"
New Altair Community Member
Updated by Jocelyn
Hi,
I have an Example Loop operator, which returns from output port IOObjectCollection. I would like to join this data to ExampleSet after the Example Loop operator and then make Aggregate on newly created ExampleSet.
Is that possible?
Thanks for ideas,
Regards,
John
1 - 3 of 31
    User: "zis"
    OP
    First idea was
    that in each iteration I save data through Store operator, but he has not an "append" mode and in each iteration he deletes original data and saves new.
    User: "zis"
    OP
    Yes,
    first idea was successful. In each iteration I used UNION operator for new data and data in Store operator and result from UNION opreator save to Store again.
    Still, is any better solution?
    Regards,
    John
    User: "MariusHelf"
    Hi,
    if all your example sets have the same attributes, the Append operator would have the same effect as Union, but is more efficient.
    Best, Marius
