<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.001" expanded="true" name="Process"> <process expanded="true" height="409" width="661"> <operator activated="true" class="generate_data" compatibility="5.2.001" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"/> <operator activated="true" class="loop_examples" compatibility="5.2.001" expanded="true" height="76" name="Loop Examples" width="90" x="246" y="30"> <process expanded="true" height="409" width="681"> <operator activated="true" class="extract_log_value" compatibility="5.2.001" expanded="true" height="60" name="Extract Log Value" width="90" x="45" y="30"> <parameter key="attribute_name" value="att1"/> <parameter key="example_index" value="%{example}"/> </operator> <operator activated="true" class="set_data" compatibility="5.2.001" expanded="true" height="76" name="Set Data" width="90" x="179" y="30"> <parameter key="example_index" value="%{example}"/> <parameter key="attribute_name" value="att1"/> <parameter key="value" value="42"/> <list key="additional_values"/> </operator> <operator activated="true" class="provide_macro_as_log_value" compatibility="5.2.001" expanded="true" height="76" name="Provide Macro as Log Value" width="90" x="313" y="120"> <parameter key="macro_name" value="example"/> </operator> <operator activated="true" class="extract_log_value" compatibility="5.2.001" expanded="true" height="60" name="Extract Log Value (2)" width="90" x="447" y="120"> <parameter key="attribute_name" value="att1"/> <parameter key="example_index" value="%{example}"/> </operator> <operator activated="true" class="log" compatibility="5.2.001" expanded="true" height="76" name="Log" width="90" x="514" y="120"> <list key="log"> <parameter key="Example" value="operator.Loop Examples.value.iteration"/> <parameter key="Before" value="operator.Extract Log Value.value.data_value"/> <parameter key="After" value="operator.Extract Log Value (2).value.data_value"/> </list> </operator> <connect from_port="example set" to_op="Extract Log Value" to_port="example set"/> <connect from_op="Extract Log Value" from_port="example set" to_op="Set Data" to_port="example set input"/> <connect from_op="Set Data" from_port="example set output" to_op="Provide Macro as Log Value" to_port="through 1"/> <connect from_op="Set Data" from_port="original" to_port="example set"/> <connect from_op="Provide Macro as Log Value" from_port="through 1" to_op="Extract Log Value (2)" to_port="example set"/> <connect from_op="Extract Log Value (2)" from_port="example set" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_port="output 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.000" expanded="true" name="Process"> <process expanded="true" height="463" width="567"> <operator activated="true" class="generate_data" compatibility="5.2.000" expanded="true" height="60" name="Generate Data" width="90" x="29" y="43"> <parameter key="number_examples" value="5"/> <parameter key="datamanagement" value="int_array"/> </operator> <operator activated="true" class="generate_id" compatibility="5.2.000" expanded="true" height="76" name="Generate ID" width="90" x="179" y="30"/> <operator activated="true" class="select_attributes" compatibility="5.2.000" expanded="true" height="76" name="Select Attributes" width="90" x="313" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="loop_examples" compatibility="5.2.000" expanded="true" height="94" name="Loop Examples" width="90" x="447" y="30"> <parameter key="iteration_macro" value="example_index"/> <process expanded="true" height="482" width="480"> <operator activated="true" class="extract_macro" compatibility="5.2.000" expanded="true" height="60" name="Extract Macro" width="90" x="45" y="30"> <parameter key="macro" value="id_value"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="id"/> <parameter key="example_index" value="%{example_index}"/> </operator> <operator activated="true" class="set_data" compatibility="5.2.000" expanded="true" height="76" name="Set Data" width="90" x="179" y="30"> <parameter key="example_index" value="%{example_index}"/> <parameter key="attribute_name" value="att2"/> <parameter key="value" value="100"/> <list key="additional_values"> <parameter key="att3" value="100"/> <parameter key="att4" value="100"/> </list> </operator> <operator activated="true" class="aggregate" compatibility="5.2.000" expanded="true" height="76" name="Aggregate" width="90" x="313" y="30"> <parameter key="use_default_aggregation" value="true"/> <parameter key="default_aggregation_function" value="sum"/> <list key="aggregation_attributes"/> </operator> <connect from_port="example set" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Set Data" to_port="example set input"/> <connect from_op="Set Data" from_port="example set output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Aggregate" from_port="example set output" to_port="output 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Generate ID" to_port="example set input"/> <connect from_op="Generate ID" from_port="example set output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="output 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process"> <process expanded="true" height="409" width="661"> <operator activated="true" class="generate_data" compatibility="5.2.003" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="number_examples" value="10"/> </operator> <operator activated="true" class="loop_examples" compatibility="5.2.003" expanded="true" height="94" name="Loop Examples" width="90" x="246" y="30"> <process expanded="true" height="409" width="820"> <operator activated="true" class="set_data" compatibility="5.2.003" expanded="true" height="76" name="Set Data" width="90" x="179" y="30"> <parameter key="example_index" value="%{example}"/> <parameter key="attribute_name" value="att1"/> <parameter key="value" value="42"/> <list key="additional_values"/> </operator> <operator activated="true" class="aggregate" compatibility="5.2.003" expanded="true" height="76" name="Aggregate" width="90" x="313" y="165"> <parameter key="use_default_aggregation" value="true"/> <list key="aggregation_attributes"/> </operator> <operator activated="true" class="collect" compatibility="5.2.003" expanded="true" height="94" name="Collect" width="90" x="514" y="165"> <parameter key="unfold" value="true"/> </operator> <connect from_port="example set" to_op="Set Data" to_port="example set input"/> <connect from_op="Set Data" from_port="example set output" to_op="Aggregate" to_port="example set input"/> <connect from_op="Set Data" from_port="original" to_port="example set"/> <connect from_op="Aggregate" from_port="example set output" to_op="Collect" to_port="input 1"/> <connect from_op="Aggregate" from_port="original" to_op="Collect" to_port="input 2"/> <connect from_op="Collect" from_port="collection" to_port="output 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="54"/> <portSpacing port="sink_output 1" spacing="36"/> <portSpacing port="sink_output 2" spacing="0"/> </process> </operator> <connect from_op="Generate Data" from_port="output" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="example set" to_port="result 1"/> <connect from_op="Loop Examples" from_port="output 1" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
