🎉Community Raffle - Win $25
Join and Win
"Confidence values"
User: "ferandi"
New Altair Community Member
Updated by Jocelyn
Hi friends,
I'm using rapidminer to make text classification with svm(libsvm), k-nn and naive bayes algorithms. So, when i get the results of my test data, i'm not sure about how each one calculates the confidence values of each instance on each class. Can anyone help me? I need this information to my article.
Thanks in advance.
1 - 8 of 81
    User: "IngoRM"
    Hi,
    this is different for each of those algorithms:
    naive bayes: the confidence is directly the calculated probability delivered by the algorithm (actually, this is one of the rare cases where the confidence IS a real probability)
    k-nn: the confidence is the number of the k neighbors with the predicted class divided by k (the single values are weighted by distace in case of weighted predictions)
    svm (I am not so sure about the LibSVM which brings another calculation in the multiclass case): for binomial classes, a good estimation of the probability for the positive class which is also used by RapidMiner is 1 / (1 + exp(-function_value))) where function_value is the SVM prediction
    Hope that helps,
    Ingo
    User: "ferandi"
    OP
    Thank you very much Ingo!!!
    User: "ferandi"
    OP
    Just one thing....what´s the concept of confidence on text classification?
    Thanks
    User: "IngoRM"
    Hi,
    well, pretty much the same as for all other kinds of classification tasks. The confidence describes how certain a prediction is. Although similar to a probability of a prediction of a specific class, it is most often not the same (with exception of some learners like Naive Bayes).
    The same applies for text classification, the confidence of a class value states how certain the model is that a document belongs to this class.
    Cheers,
    Ingo
    User: "ferandi"
    OP
    Hi, Thank you very mucho for your help!
    I need to clarify some aspects of my project:
    I'm using three different methods to classify approximately 3000 documents in 11 categories. The methods are: k-NN, Naive Bayes and SVM (libsvm linear Kernel C-SVC). After submitting the documents for each of the testing methods generates an output value with a confidence (0-1) of the document for each category and the category chosen is having the biggest confidence.
    What i´m doing is to sum the confidences of the document on each category on each 3 models and choose the label with the highest value, i guess this is called bagging, right?. Well, the fact is: my accuracy was improved about 2%. I´m yet not sure about how this confidence values are generated and normalized by Rapidminer on each model to support my conclusions. Do I have to normalize the values of each method to work together or i can consider them normalized and my result makes sense?
    Many thanks in advance!
    User: "jing_ma"
    Ingo, is there any documentation available for helping understand each algorithm's definition of confidence? Thanks!
    Jing
    Dear Jing,
    first of all: welcome to the community. There is no documentation on how our 250+ learners are calculating confidence. Most of the things are either readable in text books or in our code. Is there any operator in specific where we can help you?
    ~Martin
    User: "BenLie"
    Here just look at the sampel
     Copy from Help:
    Note that in the testing set, the attributes of the first example are Outlook = sunny and Wind = false. Naive Bayes does calculation for all possible label values and selects the label value that has maximum calculated probability.
    Calculation for label = yes
    Find product of following:
    Posterior probability of label = yes (i.e. 9/14)
    value from distribution table when Outlook = sunny and label = yes (i.e. 0.223)
    value from distribution table when Wind = false and label = yes (i.e. 0.659)
    Thus the answer = 9/14*0.223*0.659 = 0.094
    Calculation for label = no
    posterior probability of label = no (i.e. 5/14)
    value from distribution table when Outlook = sunny and label = no (i.e. 0.581)
    value from distribution table when Wind = false and label = no (i.e. 0.397)
    Thus the answer = 5/14*0.581*0.397= 0.082
    As the value for label = yes is the maximum of all possible label values, label is predicted to be yes.
    And this ist how the confidence is calculated:
    conf(yes) = 0.094/(0.094+0.082) = 0.534
    conf(no) = 0.082/(0.094+0.082) = 0,465
    Without round-off error you get:
