"Extracting text from Youtube[SOLVED]"
New Altair Community Member
Updated by Jocelyn
I am trying to use "Get Pages" operator to extract some text from Youtube pages, but get the following error:
Everything is fine with my Internet connection and I can watch YT with my browser.
1 - 13 of
131
Ok, sorry. Here it is:
http://usic.org.ua/upload/8f4ea2c9c93f56c4d624d97b63a81b8c4ebad2f3/Links.csv
Thank you in advance for your help.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>And the Links.csv file:
<process version="5.2.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.001" expanded="true" name="Process">
<process expanded="true" height="386" width="705">
<operator activated="true" class="read_csv" compatibility="5.2.001" expanded="true" height="60" name="Read CSV" width="90" x="45" y="30">
<parameter key="csv_file" value="C:\Users\Олег\Desktop\КА НаУКМА\Медіація\Links.csv"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="encoding" value="windows-1251"/>
<list key="data_set_meta_data_information"/>
</operator>
<operator activated="true" class="text:generate_extract" compatibility="5.2.001" expanded="true" height="60" name="Generate Extract" width="90" x="179" y="30">
<parameter key="source_attribute" value="Links"/>
<list key="string_machting_queries">
<parameter key="Links2" value=".&"/>
</list>
<list key="regular_expression_queries"/>
<list key="regular_region_queries"/>
<list key="xpath_queries"/>
<list key="namespaces"/>
<list key="index_queries"/>
</operator>
<operator activated="true" class="web:retrieve_webpages" compatibility="5.1.004" expanded="true" height="60" name="Get Pages" width="90" x="45" y="120">
<parameter key="link_attribute" value="Links2"/>
<parameter key="page_attribute" value="Page"/>
<parameter key="user_agent" value="Opera"/>
<parameter key="accept_cookies" value="all"/>
</operator>
<operator activated="true" class="text:generate_extract" compatibility="5.2.001" expanded="true" height="60" name="Generate Extract (2)" width="90" x="45" y="210">
<parameter key="source_attribute" value="Page"/>
<parameter key="Тривалість" value=""length_seconds": .,"/>
<parameter key="Дата" value="<span id="eow-date" class="watch-video-date" >.</span>"/>
<parameter key="Опис" value="<p id="eow-description" >.</p>"/>
<parameter key="Заголовок" value="<span id="eow-title" class="long-title" dir="ltr" title=".">"/>
<parameter key="Likes" value="<span class="likes">.</span>"/>
<parameter key="Dislikes" value="<span class="dislikes">.</span>"/>
<parameter key="Кількість коментарів" value="<span class="comments-section-stat">(.)</span>"/>
<parameter key="Кількість переглядів" value="<span class="watch-view-count"> <strong>.</strong>"/>
</list>
</operator>
<operator activated="true" class="replace" compatibility="5.2.001" expanded="true" height="76" name="Replace" width="90" x="179" y="165">
<parameter key="attribute_filter_type" value="single"/>
<parameter key="attribute" value="Post"/>
<parameter key="replace_what" value="<(.*?)>"/>
</operator>
<operator activated="true" class="replace" compatibility="5.2.001" expanded="true" height="76" name="Replace (2)" width="90" x="313" y="165">
<parameter key="replace_what" value="&(.*?);"/>
<parameter key="replace_by" value=" "/>
</operator>
<operator activated="true" class="write_csv" compatibility="5.2.001" expanded="true" height="76" name="Write CSV" width="90" x="514" y="75">
<parameter key="csv_file" value="C:\Users\Олег\Desktop\КА НаУКМА\Медіація\Youtube_extract.csv"/>
</operator>
<connect from_op="Read CSV" from_port="output" to_op="Generate Extract" to_port="Example Set"/>
<connect from_op="Generate Extract" from_port="Example Set" to_op="Get Pages" to_port="Example Set"/>
<connect from_op="Get Pages" from_port="Example Set" to_op="Generate Extract (2)" to_port="Example Set"/>
<connect from_op="Generate Extract (2)" from_port="Example Set" to_op="Replace" to_port="example set input"/>
<connect from_op="Replace" from_port="example set output" to_op="Replace (2)" to_port="example set input"/>
<connect from_op="Replace (2)" from_port="example set output" to_op="Write CSV" to_port="input"/>
</process>
</operator>
</process>
Hi,
it seems you named attributes using Eastern-Europe/Cyrillic character set, which gives a very funky "Youtube_extract.csv" at the end :-)
in the last line of your CSV there's this blank space mentionned by Nils before the "http://", which caused an error for me too. I removed the last empty line too.
have a nice day!
Alex
have a nice day!
Alex
Well, now it doesn't produce an error for "Get Pages" operator, but still doesn't extract pages content. I've simplifyed the process:
http://usic.org.ua/upload/2abf7ee83587eab166bf9e956e38b95df362fea4/Links2.csv
And here what I get:
http://usic.org.ua/upload/e5a607d60d4d88f4ed9a43e678ea03d2b8ba718a/Youtube_extract.csv
No pages extracted.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>Links2.csv file:
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="read_csv" compatibility="5.2.001" expanded="true" height="60" name="Read CSV" width="90" x="33" y="31">
<parameter key="csv_file" value="C:\Users\Олег\Desktop\КА НаУКМА\Медіація\Links2.csv"/>
</list>
<list key="data_set_meta_data_information">
<parameter key="0" value="Links.true.binominal.attribute"/>
</list>
</operator>
<operator activated="true" class="web:retrieve_webpages" compatibility="5.1.004" expanded="true" height="60" name="Get Pages" width="90" x="179" y="30">
<parameter key="follow_redirects" value="false"/>
</operator>
<operator activated="true" class="write_csv" compatibility="5.2.001" expanded="true" height="76" name="Write CSV" width="90" x="313" y="30">
</operator>
<connect from_op="Read CSV" from_port="output" to_op="Get Pages" to_port="Example Set"/>
<connect from_op="Get Pages" from_port="Example Set" to_op="Write CSV" to_port="input"/>
</process>
</operator>
</process>
No pages extracted.
Take a look at the code below and transform it for your own purposes
It reads the "links_to_check.xls" which contains the raw URL list to save
Then saves each page in HTML in a directory for further use.
Maybe isn't the coding very elegant but it works for what i needed.
Some parts of the code were taken here and there.
Alex
PS : I just started to learn RapidMiner coding 2 days ago. Ask Nils for complicated questions :-)
______________________________________________________
Alex
<context>
<input/>
<output/>
<macros/>
</context>
<process expanded="true" height="611" width="949">
<operator activated="true" class="read_excel" compatibility="5.2.001" expanded="true" height="60" name="Read Excel" width="90" x="45" y="75">
<parameter key="excel_file" value="E:\Rapidminer\reuters\links_to_check.xls"/>
</list>
<parameter key="0" value="text.true.polynominal.attribute"/>
</list>
</operator>
<operator activated="true" class="nominal_to_text" compatibility="5.2.001" expanded="true" height="76" name="Nominal to Text" width="90" x="179" y="75">
<parameter key="attribute" value="text"/>
<parameter key="include_special_attributes" value="true"/>
</operator>
<operator activated="true" class="text:process_document_from_data" compatibility="5.2.001" expanded="true" height="76" name="Process Documents from Data" width="90" x="313" y="75">
<parameter key="add_meta_information" value="false"/>
<parameter key="keep_text" value="true"/>
<list key="specify_weights"/>
<process expanded="true" height="753" width="1094">
<connect from_port="document" to_port="document 1"/>
<portSpacing port="source_document" spacing="0"/>
<portSpacing port="sink_document 1" spacing="0"/>
<portSpacing port="sink_document 2" spacing="0"/>
</process>
</operator>
<operator activated="true" class="loop_examples" compatibility="5.2.001" expanded="true" height="112" name="Loop Examples" width="90" x="447" y="75">
<process expanded="true" height="753" width="681">
<operator activated="true" class="delay" compatibility="5.2.001" expanded="true" height="76" name="Delay" width="90" x="112" y="30">
<parameter key="delay" value="random"/>
<parameter key="min_delay_amount" value="500"/>
</operator>
<operator activated="true" class="extract_macro" compatibility="5.2.001" expanded="true" height="60" name="Extract Macro" width="90" x="315" y="30">
<parameter key="macro" value="website_url"/>
<parameter key="macro_type" value="data_value"/>
<parameter key="attribute_name" value="text"/>
<parameter key="example_index" value="%{example}"/>
</operator>
<operator activated="true" class="web:get_webpage" compatibility="5.1.004" expanded="true" height="60" name="Get Page" width="90" x="112" y="165">
<parameter key="url" value="%{website_url}"/>
<parameter key="random_user_agent" value="true"/>
<list key="query_parameters"/>
</operator>
<operator activated="true" class="text:write_document" compatibility="5.2.001" expanded="true" height="60" name="Write Document" width="90" x="313" y="165">
<parameter key="file" value="E:\Rapidminer\reuters\pages_to_process\%{example}.html"/>
</operator>
<connect from_port="example set" to_op="Delay" to_port="through 1"/>
<connect from_op="Delay" from_port="through 1" to_op="Extract Macro" to_port="example set"/>
<connect from_op="Extract Macro" from_port="example set" to_port="example set"/>
<connect from_op="Get Page" from_port="output" to_op="Write Document" to_port="document"/>
<connect from_op="Write Document" from_port="document" to_port="output 2"/>
<portSpacing port="source_example set" spacing="0"/>
<portSpacing port="sink_example set" spacing="18"/>
<portSpacing port="sink_output 1" spacing="18"/>
<portSpacing port="sink_output 2" spacing="0"/>
<portSpacing port="sink_output 3" spacing="0"/>
</process>
</operator>
<operator activated="true" class="append" compatibility="5.2.001" expanded="true" height="76" name="Append" width="90" x="648" y="75"/>
<connect from_op="Read Excel" from_port="output" to_op="Nominal to Text" to_port="example set input"/>
<connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="example set" to_op="Loop Examples" to_port="example set"/>
<connect from_op="Loop Examples" from_port="output 1" to_op="Append" to_port="example set 1"/>
<connect from_op="Append" from_port="merged set" to_port="result 1"/>
</process>
</operator>
</process>
So, where is GET operator in your process? How do you download those pages?
Alex
______________________________________________________<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<context>
<input/>
<output/>
<macros/>
</context>
</list>
</list>
</operator>
</operator>
</process>
</operator>
</operator>
</operator>
</operator>
</operator>
</process>
</operator>
</process>
</operator>
</process>
Hi,
there is a problem with your process. The "Read CSV" result set has no attribute called "Links2" but an attribute called "Links". Change the "link attribute" attribute from "Get Pages" from Links2 to Links and it should work.
But still there should be an error instead of just shown an empty result set..
*edit* With the next update an error will be thrown if the selected attribute does not exists.
Best,
Nils
Best,
Nils
With this process I've managed to get what I want:
Thank you for your support.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>The problem, among others, was that .csv column separator
<context>
<input/>
<output/>
<macros/>
</context>
<process expanded="true" height="431" width="710">
</list>
</operator>
<parameter key="link_attribute" value="Links"/>
</operator>
<parameter key="Кількість переглядів" value="span class="watch-view-count">.</strong>"/>
</list>
</operator>
<parameter key="attribute" value="Опис"/>
</operator>
<parameter key="attribute" value="Кількість переглядів"/>
</operator>
<operator activated="true" class="select_attributes" compatibility="5.2.001" expanded="true" height="76" name="Select Attributes" width="90" x="380" y="30">
<parameter key="attribute_filter_type" value="subset"/>
<parameter key="attributes" value="Dislikes|Likes|Дата|Заголовок|Кількість коментарів|Кількість переглядів|Опис|Тривалість|"/>
</operator>
</operator>
<connect from_op="Replace (2)" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Write CSV" to_port="input"/>
</process>
</operator>
</process>
;was present in "Page" attribute, so I couldn't saw any meaningful result.
can you please post a example process according to http://rapid-i.com/rapidforum/index.php/topic,4654.0.html ?
If i just use the Get Pages operator everything works fine for me.
Best,
Nils
