🎉Community Raffle - Win $25
Join and Win
[SOLVED] problem installin RapidAnalytics
mazdaUser: "mazda"
New Altair Community Member
Updated by Jocelyn
Hello,
I'm getting the following error when I try to install RapidAnalytics using RapidAnalytics installer on Win 7:
Feb 10, 2012 11:22:43 PM com.rapidanalytics.installer.gui.ProgressDialog update
SEVERE: An error occured! Installation failed!
java.lang.RuntimeException: The Installer data files are missing!
       at com.rapidanalytics.installer.install.RapidAnalyticsInstallerRunnable.run(Unknown Source)
       at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
       at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
       at java.lang.Thread.run(Unknown Source)
My environment:  Win 7, MySQL 5.5, IIS 7, Java 1.6, RapidMiner 5.
Any idea why I'm getting this error? and how to fix it?
Thanks,
Mazda
1 - 2 of 21
    Hi,
    after unzipping the downloaded archive, do you have a data folder? Is it non-empty? How do you run the installer?
    Best,
    Simon
    mazdaUser: "mazda"
    OP
    Hi Simon,
    As soon as you mentioned how I was unzipping I checked the archive and realized the directory structure. So, I unzipped the archive with x option to retain the directory structure with data and jdbs subdirectories) and the installer worked.  Thank you so much for the hint.
    Regards,
    Mazda
