can not see my results
Hi everybody,
I am working with RapidMiner for a few days now and every now and then some things don't work the way I want but most works by now - until today. I can not see my results anymore. It says "Creating Display" in the right corner on the bottom, but then it says
Error executing background job 'Creating Display':
java.lang.NullPointerException
Exception: java.lang.NullPointerException
Message: null
Stack trace:
edu.uci.ics.jung.visualization.DefaultVisualizationModel.setGraphLayout(DefaultVisualizationModel.java:114)
edu.uci.ics.jung.visualization.BasicVisualizationServer.setGraphLayout(BasicVisualizationServer.java:273)
com.rapidminer.gui.graphs.GraphViewer.changeLayout(GraphViewer.java:601)
com.rapidminer.gui.graphs.GraphViewer.render(GraphViewer.java:755)
com.rapidminer.gui.processeditor.results.SingleResultOverview.<init>(SingleResultOverview.java:178)
com.rapidminer.gui.processeditor.results.ProcessExecutionResultOverview.<init>(ProcessExecutionResultOverview.java:167)
com.rapidminer.gui.processeditor.results.ResultOverview.addResults(ResultOverview.java:117)
com.rapidminer.gui.processeditor.results.DockableResultDisplay$4.run(DockableResultDisplay.java:180)
com.rapidminer.gui.tools.ProgressThread$2.run(ProgressThread.java:176)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
java.lang.Thread.run(Unknown Source)
I have about 500 different .txt files in three different folders that are loaded for text mining.
My Code:
ersion="1.0" encoding="UTF-8" standalone="no"?>
<process version="5.1.011">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.011" expanded="true" name="Process">
<process expanded="true" height="546" width="570">
<operator activated="true" class="text:process_document_from_file" compatibility="5.2.001" expanded="true" height="76" name="Process Documents from Files" width="90" x="45" y="30">
<list key="text_directories">
<parameter key="negativ" value="C:\Dokumente und Einstellungen\MuellerL\Eigene Dateien\RapidMining\Test_Daten\Deutsch\negativ"/>
<parameter key="positiv" value="C:\Dokumente und Einstellungen\MuellerL\Eigene Dateien\RapidMining\Test_Daten\Deutsch\positiv"/>
<parameter key="neutral" value="C:\Dokumente und Einstellungen\MuellerL\Eigene Dateien\RapidMining\Test_Daten\Deutsch\positiv"/>
</list>
<parameter key="file_pattern" value="*.txt"/>
<parameter key="vector_creation" value="Binary Term Occurrences"/>
<parameter key="add_meta_information" value="false"/>
<parameter key="keep_text" value="true"/>
<parameter key="prune_method" value="absolute"/>
<parameter key="prune_below_absolute" value="2"/>
<parameter key="prune_above_absolute" value="999"/>
<parameter key="prune_below_rank" value="5.0"/>
<parameter key="prune_above_rank" value="5.0"/>
<process expanded="true" height="564" width="614">
<operator activated="true" class="text:tokenize" compatibility="5.2.001" expanded="true" height="60" name="Tokenize" width="90" x="45" y="30"/>
<operator activated="true" class="text:filter_stopwords_german" compatibility="5.2.001" expanded="true" height="60" name="Filter Stopwords (German)" width="90" x="179" y="30"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.2.001" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="313" y="30">
<parameter key="min_chars" value="2"/>
</operator>
<operator activated="true" class="text:replace_tokens" compatibility="5.2.001" expanded="true" height="60" name="Replace Tokens" width="90" x="447" y="30">
<list key="replace_dictionary">
<parameter key="Coca Cola" value="Coca-Cola"/>
<parameter key="Coca" value="Coca-Cola"/>
<parameter key="Cola" value="Coca-Cola"/>
</list>
</operator>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (German)" to_port="document"/>
<connect from_op="Filter Stopwords (German)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Replace Tokens" to_port="document"/>
<connect from_op="Replace Tokens" from_port="document" to_port="document 1"/>
<portSpacing port="source_document" spacing="0"/>
<portSpacing port="sink_document 1" spacing="0"/>
<portSpacing port="sink_document 2" spacing="0"/>
</process>
</operator>
<operator activated="true" class="numerical_to_binominal" compatibility="5.1.011" expanded="true" height="76" name="Numerical to Binominal" width="90" x="180" y="30"/>
<operator activated="true" class="fp_growth" compatibility="5.1.011" expanded="true" height="76" name="FP-Growth" width="90" x="315" y="30">
<parameter key="min_support" value="0.05"/>
</operator>
<operator activated="true" class="create_association_rules" compatibility="5.1.011" expanded="true" height="76" name="Create Association Rules" width="90" x="450" y="30">
<parameter key="criterion" value="lift"/>
<parameter key="min_criterion_value" value="0.2"/>
</operator>
<connect from_op="Process Documents from Files" from_port="example set" to_op="Numerical to Binominal" to_port="example set input"/>
<connect from_op="Process Documents from Files" from_port="word list" to_port="result 1"/>
<connect from_op="Numerical to Binominal" from_port="example set output" to_op="FP-Growth" to_port="example set"/>
<connect from_op="FP-Growth" from_port="frequent sets" to_op="Create Association Rules" to_port="item sets"/>
<connect from_op="Create Association Rules" from_port="rules" to_port="result 2"/>
<portSpacing port="sink_result 2" spacing="36"/>
<portSpacing port="sink_result 3" spacing="0"/>
</process>
</operator>
</process>
Thanks for your help!
Message: null
Stack trace:
My Code:
<context>
<input/>
<output/>
<macros/>
</context>
</list>
</operator>
</list>
</operator>
</process>
</operator>
</operator>
</operator>
</process>
</operator>
</process>
1 - 7 of
71
Hi there,
Just a thought, but it could be related to an issue addressed in another thread, http://rapid-i.com/rapidforum/index.php/topic,3619.msg13530.html#msg13530 . I know from experience that the association rules operator chokes if there are itemsets containing more than a small number of items. That is what I pointed out in the other thread last April. So you might have generated itemsets that are too long, in which case you could try setting the frequency threshold a bit higher.
Just my two ...
Just my two ...
I can reproduce this error with just having a few itemsets (see the following sample XML: http://rapid-i.com/rapidforum/index.php/topic,4685.0.html)
It seems that the error only occurs with the newest version
I think the problem here was the creation of a GraphRenderer with too much items. Before it only checked if there are rules to render, now if there are more then 500 rules only the best 500 rules will be rendered in the "Graph View". For slower machines this still might be slow but shouldn't block your machine anymore.
Greetings,
Nils
Greetings,
Nils
did the process run just fine before? If so, you can try "View" - "Restore Default Perspective", this might fix the problem.
If not, please make sure you are using the latest RapidMiner version (5.2) and try again. If the problem persists, I'm afraid that I cannot help you right now, but we are aware of this issue and looking into it.
Regards,
Marco
