Hi
I have a Date attribute which is sometimes missing. In that case, I use the value "NULL" when I create the field ("Generate Attributes"). In the database, I end up with the value "1970-01-01" instead of NULL. What should I do to have actual NULL values in the database?
TIA
greg
