Attributes names and import process
About attribute names, they seems to be very "old school" (only characters, like a regular programming language), am I right?
The "import" command however is not as rigid, so I end up with attributes containing spaces and accentuated chars.
So my question is: when I have a repository created by he "import" command, and has bad attribute names, is it possible to "correct" the repository without re-doing the import process?
TIA
greg
PS: BTW I don't know if it's a known bug, but on my system importing an excel sheet only works the first time after launch (meaning to import another one I have to quit and relaunch rapidminer)
TIA
greg
1 - 2 of
21
First of all let me state that RapidMiner is capable of dealing with all character sets since you can also specify the file encoding within the import wizard.
You can use the Operator Rename which gives you the possibility to rename all attributes within one operator.
Please keep in mind that you should not use blanks or hyphens within the new names if you want to compute e.g. the difference between the values of those attributes.
Best,
Edin
