🎉Community Raffle - Win $25
Join and Win
How to install RA in existing Jboss installations
User: "Magick"
New Altair Community Member
Updated by Jocelyn
Hi
Im wondering if it is possible to deploy RA to an existing JBoss installation?
Ive tried various approaches, such as uploading the rapidanalytics.xxx.ear file, and also putting the various .jar files in the standalone/lib folder, however Im still getting errors.
the log from Jboss is;
02:56:34,484 INFO  [org.jboss.as.server.deployment] (MSC service thread 1-1) Starting deployment of "RapidAnalytics-CE-1.1.014.ear"
02:56:35,755 INFO  [org.jboss.as.server.deployment] (MSC service thread 1-3) Starting deployment of "RapidRepositoryEJB.jar"
02:56:35,755 INFO  [org.jboss.as.server.deployment] (MSC service thread 1-3) Starting deployment of "RapidRepositoryWebService.war"
02:56:35,755 INFO  [org.jboss.as.server.deployment] (MSC service thread 1-3) Starting deployment of "RapidRepositoryWeb.war"
02:56:36,116 WARN  [org.jboss.as.server.deployment] (MSC service thread 1-3) Class Path entry  in "/content/RapidAnalytics-CE-1.1.014.ear/lib/RapidRepositorySSO.jar" does not point to a valid jar for a Class-Path reference.
02:56:36,117 WARN  [org.jboss.as.server.deployment] (MSC service thread 1-3) Class Path entry  in "/content/RapidAnalytics-CE-1.1.014.ear/lib/RapidRepositoryTools.jar" does not point to a valid jar for a Class-Path reference.
02:56:36,117 WARN  [org.jboss.as.server.deployment] (MSC service thread 1-3) Class Path entry  in "/content/RapidAnalytics-CE-1.1.014.ear/lib/RapidMiner_Vega.jar" does not point to a valid jar for a Class-Path reference.
02:56:36,118 INFO  [org.jboss.jpa] (MSC service thread 1-3) read persistence.xml for RapidRepositoryEntity
02:56:36,262 INFO  [org.jboss.as.jpa] (MSC service thread 1-4) added javax.persistence.api, javaee.api, org.jboss.as.jpa, org.javassist dependencies to RapidAnalytics-CE-1.1.014.ear
02:56:36,263 INFO  [org.jboss.as.jpa] (MSC service thread 1-4) added (default provider) org.hibernate dependency to application deployment (since 1 PU(s) didn't specify jboss.as.jpa.providerModule)
02:56:36,263 INFO  [org.jboss.as.jpa] (MSC service thread 1-4) added org.hibernate dependency to application deployment
02:56:36,264 INFO  [org.jboss.as.jpa] (MSC service thread 1-4) added javax.persistence.api, javaee.api, org.jboss.as.jpa, org.javassist dependencies to RapidRepositoryWeb.war
02:56:36,264 INFO  [org.jboss.as.jpa] (MSC service thread 1-4) added javax.persistence.api, javaee.api, org.jboss.as.jpa, org.javassist dependencies to RapidRepositoryEJB.jar
02:56:36,265 INFO  [org.jboss.as.jpa] (MSC service thread 1-4) added javax.persistence.api, javaee.api, org.jboss.as.jpa, org.javassist dependencies to RapidRepositoryWebService.war
02:56:36,396 INFO  [org.jboss.as.ejb3.deployment.processors.EjbJndiBindingsDeploymentUnitProcessor] (MSC service thread 1-2) JNDI bindings for session bean named RepositoryEJBImpl in deployment unit subdeployment "RapidRepositoryEJB.jar" of deployment "RapidAnalytics-CE-1.1.014.ear" are as follows:
java:global/RapidAnalytics-CE-1.1.014/RapidRepositoryEJB/RepositoryEJBImpl!de.rapidanalytics.ejb.RepositoryEJB
java:app/RapidRepositoryEJB/RepositoryEJBImpl!de.rapidanalytics.ejb.RepositoryEJB
java:module/RepositoryEJBImpl!de.rapidanalytics.ejb.RepositoryEJB
02:56:36,396 INFO  [org.jboss.as.ejb3.deployment.processors.EjbJndiBindingsDeploymentUnitProcessor] (MSC service thread 1-2) JNDI bindings for session bean named RapidMinerEJBImpl in deployment unit subdeployment "RapidRepositoryEJB.jar" of deployment "RapidAnalytics-CE-1.1.014.ear" are as follows:
java:global/RapidAnalytics-CE-1.1.014/RapidRepositoryEJB/RapidMinerEJBImpl!de.rapidanalytics.ejb.RapidMinerEJB
java:app/RapidRepositoryEJB/RapidMinerEJBImpl!de.rapidanalytics.ejb.RapidMinerEJB
java:module/RapidMinerEJBImpl!de.rapidanalytics.ejb.RapidMinerEJB
02:56:36,396 INFO  [org.jboss.as.ejb3.deployment.processors.EjbJndiBindingsDeploymentUnitProcessor] (MSC service thread 1-2) JNDI bindings for session bean named AccessLogEJBImpl in deployment unit subdeployment "RapidRepositoryEJB.jar" of deployment "RapidAnalytics-CE-1.1.014.ear" are as follows:
java:global/RapidAnalytics-CE-1.1.014/RapidRepositoryEJB/AccessLogEJBImpl!de.rapidanalytics.ejb.AccessLogEJB
java:app/RapidRepositoryEJB/AccessLogEJBImpl!de.rapidanalytics.ejb.AccessLogEJB
java:module/AccessLogEJBImpl!de.rapidanalytics.ejb.AccessLogEJB
02:56:36,397 INFO  [org.jboss.as.ejb3.deployment.processors.EjbJndiBindingsDeploymentUnitProcessor] (MSC service thread 1-2) JNDI bindings for session bean named MigrationEJBImpl in deployment unit subdeployment "RapidRepositoryEJB.jar" of deployment "RapidAnalytics-CE-1.1.014.ear" are as follows:
java:global/RapidAnalytics-CE-1.1.014/RapidRepositoryEJB/MigrationEJBImpl!de.rapidanalytics.ejb.MigrationEJB
java:app/RapidRepositoryEJB/MigrationEJBImpl!de.rapidanalytics.ejb.MigrationEJB
java:module/MigrationEJBImpl!de.rapidanalytics.ejb.MigrationEJB
02:56:36,397 INFO  [org.jboss.as.ejb3.deployment.processors.EjbJndiBindingsDeploymentUnitProcessor] (MSC service thread 1-2) JNDI bindings for session bean named UserManagementEJBImpl in deployment unit subdeployment "RapidRepositoryEJB.jar" of deployment "RapidAnalytics-CE-1.1.014.ear" are as follows:
java:global/RapidAnalytics-CE-1.1.014/RapidRepositoryEJB/UserManagementEJBImpl!de.rapidanalytics.ejb.UserManagementEJB
java:app/RapidRepositoryEJB/UserManagementEJBImpl!de.rapidanalytics.ejb.UserManagementEJB
java:module/UserManagementEJBImpl!de.rapidanalytics.ejb.UserManagementEJB
02:56:36,397 INFO  [org.jboss.as.ejb3.deployment.processors.EjbJndiBindingsDeploymentUnitProcessor] (MSC service thread 1-2) JNDI bindings for session bean named ProcessHelperEJBImpl in deployment unit subdeployment "RapidRepositoryEJB.jar" of deployment "RapidAnalytics-CE-1.1.014.ear" are as follows:
java:global/RapidAnalytics-CE-1.1.014/RapidRepositoryEJB/ProcessHelperEJBImpl!de.rapidanalytics.ejb.ProcessHelperEJB
java:app/RapidRepositoryEJB/ProcessHelperEJBImpl!de.rapidanalytics.ejb.ProcessHelperEJB
java:module/ProcessHelperEJBImpl!de.rapidanalytics.ejb.ProcessHelperEJB
02:56:36,397 INFO  [org.jboss.as.ejb3.deployment.processors.EjbJndiBindingsDeploymentUnitProcessor] (MSC service thread 1-2) JNDI bindings for session bean named ExportedProcessEJBImpl in deployment unit subdeployment "RapidRepositoryEJB.jar" of deployment "RapidAnalytics-CE-1.1.014.ear" are as follows:
java:global/RapidAnalytics-CE-1.1.014/RapidRepositoryEJB/ExportedProcessEJBImpl!de.rapidanalytics.ejb.ExportedProcessEJB
java:app/RapidRepositoryEJB/ExportedProcessEJBImpl!de.rapidanalytics.ejb.ExportedProcessEJB
java:module/ExportedProcessEJBImpl!de.rapidanalytics.ejb.ExportedProcessEJB
02:56:36,397 INFO  [org.jboss.as.ejb3.deployment.processors.EjbJndiBindingsDeploymentUnitProcessor] (MSC service thread 1-2) JNDI bindings for session bean named TriggerEJBImpl in deployment unit subdeployment "RapidRepositoryEJB.jar" of deployment "RapidAnalytics-CE-1.1.014.ear" are as follows:
java:global/RapidAnalytics-CE-1.1.014/RapidRepositoryEJB/TriggerEJBImpl!de.rapidanalytics.ejb.TriggerEJB
java:app/RapidRepositoryEJB/TriggerEJBImpl!de.rapidanalytics.ejb.TriggerEJB
java:module/TriggerEJBImpl!de.rapidanalytics.ejb.TriggerEJB
02:56:36,398 INFO  [org.jboss.as.ejb3.deployment.processors.EjbJndiBindingsDeploymentUnitProcessor] (MSC service thread 1-2) JNDI bindings for session bean named RepositoryStorageEJBImpl in deployment unit subdeployment "RapidRepositoryEJB.jar" of deployment "RapidAnalytics-CE-1.1.014.ear" are as follows:
java:global/RapidAnalytics-CE-1.1.014/RapidRepositoryEJB/RepositoryStorageEJBImpl!de.rapidanalytics.ejb.RepositoryStorageEJB
java:app/RapidRepositoryEJB/RepositoryStorageEJBImpl!de.rapidanalytics.ejb.RepositoryStorageEJB
java:module/RepositoryStorageEJBImpl!de.rapidanalytics.ejb.RepositoryStorageEJB
02:56:36,398 INFO  [org.jboss.as.ejb3.deployment.processors.EjbJndiBindingsDeploymentUnitProcessor] (MSC service thread 1-2) JNDI bindings for session bean named TriggerManagementEJBImpl in deployment unit subdeployment "RapidRepositoryEJB.jar" of deployment "RapidAnalytics-CE-1.1.014.ear" are as follows:
java:global/RapidAnalytics-CE-1.1.014/RapidRepositoryEJB/TriggerManagementEJBImpl!de.rapidanalytics.ejb.TriggerManagementEJB
java:app/RapidRepositoryEJB/TriggerManagementEJBImpl!de.rapidanalytics.ejb.TriggerManagementEJB
java:module/TriggerManagementEJBImpl!de.rapidanalytics.ejb.TriggerManagementEJB
02:56:36,398 INFO  [org.jboss.as.ejb3.deployment.processors.EjbJndiBindingsDeploymentUnitProcessor] (MSC service thread 1-2) JNDI bindings for session bean named ProcessJobEJBImpl in deployment unit subdeployment "RapidRepositoryEJB.jar" of deployment "RapidAnalytics-CE-1.1.014.ear" are as follows:
java:global/RapidAnalytics-CE-1.1.014/RapidRepositoryEJB/ProcessJobEJBImpl!de.rapidanalytics.ejb.ProcessJobEJB
java:app/RapidRepositoryEJB/ProcessJobEJBImpl!de.rapidanalytics.ejb.ProcessJobEJB
java:module/ProcessJobEJBImpl!de.rapidanalytics.ejb.ProcessJobEJB
02:56:36,398 INFO  [org.jboss.as.ejb3.deployment.processors.EjbJndiBindingsDeploymentUnitProcessor] (MSC service thread 1-2) JNDI bindings for session bean named SchedulerEJBImpl in deployment unit subdeployment "RapidRepositoryEJB.jar" of deployment "RapidAnalytics-CE-1.1.014.ear" are as follows:
java:global/RapidAnalytics-CE-1.1.014/RapidRepositoryEJB/SchedulerEJBImpl!de.rapidanalytics.ejb.SchedulerEJB
java:app/RapidRepositoryEJB/SchedulerEJBImpl!de.rapidanalytics.ejb.SchedulerEJB
java:module/SchedulerEJBImpl!de.rapidanalytics.ejb.SchedulerEJB
02:56:36,398 INFO  [org.jboss.as.ejb3.deployment.processors.EjbJndiBindingsDeploymentUnitProcessor] (MSC service thread 1-2) JNDI bindings for session bean named UserCreationEJBImpl in deployment unit subdeployment "RapidRepositoryEJB.jar" of deployment "RapidAnalytics-CE-1.1.014.ear" are as follows:
java:global/RapidAnalytics-CE-1.1.014/RapidRepositoryEJB/UserCreationEJBImpl!de.rapidanalytics.ejb.UserCreationEJB
java:app/RapidRepositoryEJB/UserCreationEJBImpl!de.rapidanalytics.ejb.UserCreationEJB
java:module/UserCreationEJBImpl!de.rapidanalytics.ejb.UserCreationEJB
02:56:36,485 ERROR [org.jboss.msc.service.fail] (MSC service thread 1-3) MSC00001: Failed to start service jboss.deployment.subunit."RapidAnalytics-CE-1.1.014.ear"."RapidRepositoryWebService.war".INSTALL: org.jboss.msc.service.StartException in service jboss.deployment.subunit."RapidAnalytics-CE-1.1.014.ear"."RapidRepositoryWebService.war".INSTALL: Failed to process phase INSTALL of subdeployment "RapidRepositoryWebService.war" of deployment "RapidAnalytics-CE-1.1.014.ear"
at org.jboss.as.server.deployment.DeploymentUnitPhaseService.start(DeploymentUnitPhaseService.java:121) [jboss-as-server-7.0.2.Final.jar:7.0.2.Final]
at org.jboss.msc.service.ServiceControllerImpl$StartTask.startService(ServiceControllerImpl.java:1824) [jboss-msc-1.0.1.GA.jar:1.0.1.GA]
at org.jboss.msc.service.ServiceControllerImpl$StartTask.run(ServiceControllerImpl.java:1759) [jboss-msc-1.0.1.GA.jar:1.0.1.GA]
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886) [:1.6.0_22]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908) [:1.6.0_22]
at java.lang.Thread.run(Thread.java:662) [:1.6.0_22]
Caused by: java.lang.RuntimeException: Failed to load class org.springframework.web.util.Log4jConfigListener
at org.jboss.as.ee.component.deployers.EEClassConfigurationProcessor$1.compute(EEClassConfigurationProcessor.java:141)
at org.jboss.as.ee.component.deployers.EEClassConfigurationProcessor$1.compute(EEClassConfigurationProcessor.java:122)
at org.jboss.as.ee.component.LazyValue.get(LazyValue.java:40)
at org.jboss.as.ee.component.EEApplicationDescription.getClassConfiguration(EEApplicationDescription.java:183)
at org.jboss.as.ee.component.ComponentDescription.createConfiguration(ComponentDescription.java:153)
at org.jboss.as.ee.component.deployers.EEModuleConfigurationProcessor.deploy(EEModuleConfigurationProcessor.java:70)
at org.jboss.as.server.deployment.DeploymentUnitPhaseService.start(DeploymentUnitPhaseService.java:115) [jboss-as-server-7.0.2.Final.jar:7.0.2.Final]
... 5 more
Caused by: java.lang.ClassNotFoundException: org.springframework.web.util.Log4jConfigListener from [Module "deployment.RapidAnalytics-CE-1.1.014.ear.RapidRepositoryWebService.war:main" from Service Module Loader]
at org.jboss.modules.ModuleClassLoader.findClass(ModuleClassLoader.java:191)
at org.jboss.modules.ConcurrentClassLoader.performLoadClassChecked(ConcurrentClassLoader.java:361)
at org.jboss.modules.ConcurrentClassLoader.performLoadClassChecked(ConcurrentClassLoader.java:333)
at org.jboss.modules.ConcurrentClassLoader.performLoadClass(ConcurrentClassLoader.java:310)
at org.jboss.modules.ConcurrentClassLoader.loadClass(ConcurrentClassLoader.java:103)
at java.lang.Class.forName0(Native Method) [:1.6.0_22]
at java.lang.Class.forName(Class.java:247) [:1.6.0_22]
at org.jboss.as.ee.component.deployers.EEClassConfigurationProcessor$1.compute(EEClassConfigurationProcessor.java:139)
... 11 more
02:56:36,506 ERROR [org.jboss.msc.service.fail] (MSC service thread 1-4) MSC00001: Failed to start service jboss.deployment.subunit."RapidAnalytics-CE-1.1.014.ear"."RapidRepositoryWeb.war".INSTALL: org.jboss.msc.service.StartException in service jboss.deployment.subunit."RapidAnalytics-CE-1.1.014.ear"."RapidRepositoryWeb.war".INSTALL: Failed to process phase INSTALL of subdeployment "RapidRepositoryWeb.war" of deployment "RapidAnalytics-CE-1.1.014.ear"
... 5 more
... 11 more
1 - 1 of 11
    User: "fischer"
    Hi,
    this should of course be possible. Just follow the instructions in for the manual installation. What JBoss version are you using? JBoss 6.0.0 Final definitely works. JBoss 7 is untested.
    Best,
    Simon
