Generate Attribute containing process information
Hi,
I would very much like to create an attribute containing information about the process itsself before I write my data to file. So, there is a function set called "process" available in the "Generate Attributes" operator containing a function called "params()". So I assume this is possible and I just couldn't figure out the correct syntax. The (at least to me) obvious "params(Operator.Parameter)" did not work. Anyone know how to do this???
cheers,
Tim
cheers,
Tim
1 - 1 of
11
you found a bug in the formula editor - it does not recognize the param() function. The syntax is: , e.g. Best regards,
Marius
