unparsable time
hi every body.
I am new in rapidminer, and I have problem loading my data to rapidminer by ReadExcell, I will appreciate if anyone help me.
I have a colomn named time. and it has data that are in time format : for example : 01:00:46.644337
rapidminer uses polynomial type for that automaticaly, I changed it to time but I got the error unparsable time. :
what can I do to solve this problem.
thanks alot.
thanks alot.
1 - 12 of
121
dear chris
I have problem using the method you mentioned.
I use date_parse_custom(time,"HH:mm:ss.ffffff") under the function operation but get a strange error. am I wrong?
then I tried this method like this :(time,"HH:mm:ss") and had to remove that part. this way I didn't get error but it shows date in the colomn. what can I do to see only time.
although I used DATE_SHOW_TIME_ONLY constant as the third argument it did not change
date_parse_custom(time,"HH:mm:ss","DATE_SHOW_TIME_ONLY ")
thank you very much
thank you very much
I'm sorry, here I don't know what to do, because in my cases I didn't work with milliseconds and I had full dates. My only idea would be to use the operator "Guess Types" afterwards, but I'm not sure if it will recognize that it's not a date but just time...
I wish you much luck solving your problem anyway.
Best regards,
Chris
Best regards,
Chris
thanks for your reply.
actually, I have one column that is just time , and another column that is just date, and I don't have any problem with the date column, it's type is recognized automatically to date-time, and when I change it to date there is no problem,. can I do something to combine these two columns to have one date-time column?
I really appreciate your time. sorry for asking continues questions. I have to do this project, and there is little time .
Hi,
yes, you could first use both attributes with value type "nominal" (or transform them first, see below), then you can simple use the operator "Generate Concatenation" to combine both columns. Instead of using "Generate Attributes" and the data_parse functions, you could also use the probably simpler operators "Nominal to Date" and "Date to Nominal" instead, which can also handle times. I have uploaded a process to myexperiment.org demonstrating the desired time and date conversions, you can simply download it with the "Community" extension of RapidMiner:
http://www.myexperiment.org/workflows/2596.html
The main problem might derive from the fact that "01:00:46.644337" is not a proper date at all: "644337" milliseconds do not make any sense at all. If the time would only be "01:00:46.644" things are pretty easy (as the process above shows), here the correct parse string would be "hh:mm:ss.SSS" and all methods will be able to parse the time correctly. Please note, however, that RapidMiner will not display the milliseconds for time attributes but it still stores the information as can be seen after the re-transforming with "Date to Nominal" in the process above.
Cheers,
Ingo
Cheers,
Ingo
http://www.4shared.com/photo/gN0erq11/1_online.html
http://www.4shared.com/photo/EbL9wFdN/2_online.html
http://www.4shared.com/photo/HPfSthFM/3_online.html
sorry, would you please take a look at this image..
I have put the first Nominal to date for the column date in my data. and the second for the time column in my data. I have already removed the millisecond part of the time.
the third operator(Date to Nominal) I have placed there is for combining these two columns to one date-time attribute.
I don't know what to set data format and attribute name there
and I don't know how to do the setting for data format, in these three operators.
thanks for your help
@Ingo Mierswa : Oh yes, there is a direct nominal to date operator. In my cases I never had to use that, so sorry for my more complicated way
@roya67: I'm not exactly sure what you want to get, but you should use the "Generate Concatenation" Operator without converting the attributes to date. Then you should get a nominal value showing your full date with time. If you want to have a date attribute in the end, then you should convert it with the "Nominal to Date" Operator afterwards in one step including date and time. So I think you can do it with just these two operators....
Chris
Chris
I also have some problems with the time handling in RapidMiner, especially when I extracted it with a macro and then writing it back as date. So I can maybe give you an idea for an workaround:
My approach would be this: You should be able to read the date as nominal value. Then with the "Generate Attributes"-operator you can generate a new attribute using the function "date_parse_custom", which uses your nominal date and an additional Pattern String as Input according to your format (I think it should be "HH:mm:ss.ffffff"). As result the new attribute should contain your value as date/time.
Best regards,
Chris
