🎉Community Raffle - Win $25
Join and Win
Select Attributes by Role, eg. drop all special attributes.
User: "dragoljub"
New Altair Community Member
Updated by Jocelyn
Hi Everyone,
Is there any way to filter attributes by Role? For example I would like to select all non-special attributes. Basically all attributes whose role is regular. This will be useful for writing CSV files without the special attributes. I would use write special to do accomplish the same thing (only writing the regular attributes) but write special has no potion to output an attribute name header.
Adding a Role attribute filter type in Select Attributes would be a great feature.  ;D
-Gagi
1 - 2 of 21
    User: "Nils_Woehler"
    Hi,
    unfortunately it is not possible to automaticly select all non-special attributes. But you can use a workaround by using the "Select Attributes" operator.
    Use the option subset and select all special attributes. Finally check invert selection and include special attributes. This way you get only non-special attributes.
    Greetings,
    Nils
    User: "dragoljub"
    OP
    We'll that's exactly what I'm trying to avoid. If I have 30-40 special attributes with different names it makes no sense (takes too long) to manually select them all.  :-[
    There really should be a selection option based on role. Also Write CSV should have an option to include or exclude writing of special attributes. Likewise write special should have the same option, and an option to include the attribute name header.
    ;D
    -Gagi
