🎉Community Raffle - Win $25
Join and Win
Discretize with same bins
User: "iason"
New Altair Community Member
Updated by Jocelyn
This is probably something really simple but I couldn't find a solution.
If I create a model based on discretization by frequency, can the bin boundaries be extracted from a different dataset?
If not, how can a model be applied on unlabeled examples? The bins will have different boundaries if run through the discretize by frequency operator.
From the help it seems like there should be a checkbox for "return preprocessing model" which should do what I am asking, but the checkbox is not there.
It might be that the pre output is always enabled.
Even if I use the "pre" output of the discretize node, how do I apply to the dataset?
1 - 1 of 11
    User: "iason"
    OP
    I think "apply model" with pre connected to mod works correctly.
    Should have tried around more before posting.
    Help is misleading, however.
