🎉Community Raffle - Win $25
Join and Win
Deleting data from repositories
User: "vme64"
New Altair Community Member
Updated by Jocelyn
Hello,
  I split my processing in several processes which communicate through dIatasets stored in repositories, to ease debugging and to avoiding the execution of the whole workflow when I change just the last steps. But I would like to remove some of the intermediate results in the end of the processing chain, as they can get rather big and I backup them all in my limited 2GB Dropbox... But I did not find a programmatic way to delete things from repositories, just with mouse/keyboard. Is there a way to do this, through an operator or through a groovy scripts?
  As a possible feature suggestion: perhaps some kind of "cached" datasets, which could be all cleaned on demand, would be nice.
Best regards,
  Vinicius
1 - 2 of 21
    User: "Aj"
    Hi,
    How about reading the old repository first, then pass it through "select attributes" to filter out the attributes you do not want and rewriting it to a new repository? After that, you can possibly delete the old repository and start using the new repository from now on.
    Thanks,
    Ajay
    User: "Marco_Boeck"
    Hi,
    there is no operator to do that for you, but this groovy script could help you.
    import com.rapidminer.repository.Repository;
    import com.rapidminer.repository.RepositoryLocation;
    import com.rapidminer.repository.Entry;
    RepositoryLocation loc = new RepositoryLocation("//LocalRepository/path/to/delete/nameOfEntry");
    Entry entry = loc.locateEntry();
    entry.delete();
    I do not recommend doing this, but it's possible.
    Regards,
    Marco
