"installing latest versions of rapid miner 32/64"
i recently installed the latest version of rapid miner 5.18. after running updates, it says i need admin privileges to continue with update. also, it does not high light the extensions i need saying it is already installed but i can not see it in the list of operators. i would appreciate any guide on how i can display these extensions. thank you. - reena
1 - 2 of
21
it seems that the update function is not working. it says that you have the updated version but the icons do not appear (and therefore, the plugins are not found in the operators). i had to do a manual download of the extensions i needed. now the icons appear when you run rapidminer.
