Carbon Fibre Tows Simulation in Hypermesh
Dear Community,
my name is Lennart, I am a composites engineering student from Germany and I have started working with Optistruct/Hypermesh full-time since a few weeks. I am trying to get ahold of composite optimisation.
Optistruct is only partially able to compute composite parts. it appears that I am very limited in the design of more complex parts. What I am looking for in particular is a way to not only design plies in flat structures, but rather tows and roving in 3D parts, for example a scaffold of a crane or similar.
I AM able to model 3D composite structures by designing surfaces which come close to the 3D part and apply a laminate as a workaround.
As a first step towards 3D composite optimisation, I would like to have a workaround solution for working with single tows. For example if I have a 2D circular part, let's say a simple ring.
If I apply a tensile force (with a bolt or similar), the ideal optimisation result for a minimum displacement of the circle geometry would be a 'ring' of carbon fibres. However I am not quite sure how to get this result in Optistruct. This is not possible when the program only 'thinks' with plies.
is there any way how I could achieve this result with the given Optistruct possibilites? Any way to 'cheat' and work with single fibre tows instead of plies?
Any help would be greatly apprechiated.
Regards,
Lenny
I am interested in finding the optimum ply lay-up for my complex CFRP part and I am trying to understand how to make Hypermesh/Optistruct do what I want it to do by starting off with simple geometries and working my way up.
Ultimately, I want my to optimize the topology of my part and have carbon fibres places ideally for all load cases.
As for the ring geometry:
I am applying the force on the center of a Rigid Body Element (RBE2), which connects its centre node to all the nodes on the inner 'line' of the ring.
So I am applying the force at the middle.
OK thanks. I will try to reproduce the a similar situation. Just another question. Is the force normal to ply surface?
I am working with free size instead of topology just to check the pattern. So far no success..
Let me explain what I have done so far...
1) 4 layers of plies
2) Applied a force in the middle on a RBE2
3) Cyclic pattern constrain used
Let me know if this is what you are doing...
This is exactly what I am looking for.
I used multiple plies with steps of 5°, to get a more accurate result, but this should work just as fine.
The optimum result of the fibre orientation optimisation should be forming a 'ring' within the circular part, which, in reality, is the ideal fibre positioning.
However as mentioned, I am unsure how to achieve the expected optimum result. I am unsure if Optistruct is able to compute this case with realistic results.
I applied a moment around the axis of disc. With load perpendicular to axis was not helpful at all. I attached the model file.
Wow! This is exactly what I was looking for!
if you don't mind me asking, how did you manage to make the 0° ply direction go in a circular manner?
I can only get it to point into one global direction (x,y,z), but having the ply/material direction go in circles around the part should come quite handy!
Your support is amazing, thank you so much.
Create a cylindrical coordinate system. I assumed 0deg in the direction of radius and anything perpendicular will be 90deg which lays fiber in circular manner.
Hi @Lenny
What type of optimization are you interested in?
How are you applying the forces in the circular ring?
Is it on the circumference or at the middle?
