Information about Generate ID attributes
Hello,
I want to know how work the special attribute ID. In particular when I add this attribute to an exampleSet with the generate id attribute, is it the same ID added by the k-means clustering operator? I ask this because my problem is the follow: i made a clustering with k-means using a subset of features, but after clustering I want to explore the examples in each cluster also for the features not used for clustering. So what i done is adding an id to the original dataset and then join the clusteredSet with the original dataset by the ID, but I want to be sure that the two ID are the same in the generated one and in the clusteredSet. Thank you to all.
1 - 1 of
11
Cheers,
Marius
