1 - 4 of
41
thank you Marco,
it works, BUT I had to convert nominal label of interest into numerical and after filtering back into nominal. This is really clumsy way to do something like value range
selection. :-\
Hope this will be implemented as part of a single operator e.g. filter examples including nominal list filtering or perl like script selection.
cheers
selection. :-\
cheers
you can use this process: You just need to specify the range in the Generate Attribute operator, rename the column from "Test" to whatever you need and you're good to go
Regards,
Marco
