"RapidMiner Association Rules / transaction based dataset"
User: "TomLeey"
New Altair Community Member
Updated by Jocelyn
Hello,
maybe someone here has already had experiences with this topic. I have itemsets that represent orders. The format  is:
OrderID    Item
1234        10
1234        12
1267        3
1288        3
My problem is, that the nominal-2-binominal operator doesn`t support this format. Using this Operator, it creates binominal datalines for each row. What i need is a grouping by the corresponding OrderID.
I spend a lot of time for finding a solution but i didn`t get any answers yet - although it seem to represent a common data-format.
Thanks for youre help !
1 - 4 of 41
    Hi,
    I'm not sure what your desired output is. This?
    OrderID    Item
    1234        10, 12
    1267        3
    1288        3
    Something else?
    Regards,
    Marco
    User: "TomLeey"
    OP
    Well, I think the FP-Growth Operator needs the following resulttable:
    OrderID          Item_10      Item_12      Item_3
    1234              true            true            false
    1267              false          false          true
    1288              false          false          true
    I want to search for association rules in the item sets. Therefore i have to use the FP-Growth Operator.
    Thanks for your'e reply
    User: "Rene"
    check out this posting from haddock:
    http://rapid-i.com/rapidforum/index.php/topic,1821.msg7227.html#msg7227
    happy mining. ;)
    User: "TomLeey"
    OP
    Is it also possible to do so without having an amount ? Surely its possible to use amount=1 but
    the questions is whether there is a simpler solution.
    Thanks for youre reply. I already had a look on the mentioned topic.
