1 - 5 of
51
Hi Colo,
Thanks a lot for your Help. I want to compare two Columns, for example alt_adress with new_adress, if they are same, give me as answer in new columns "yes" otherweise "No". or, as in haming Distance algorithm said, what percentage of a cell in alte_adress with the same cell in new_adress is consistent.
with best regard.
with best regard.
Hi Wolfsburg,
if you just want to check if the column values are equal you can do it very easily this way:
Regards
Matthias
<?xml version="1.0" encoding="UTF-8" standalone="no"?>If you want to achieve some sort of similarity measurement you will have to include more sophisticated methods. "Generate Attributes" allows to use some string methods (like prefix, suffix, contains, regex matching) but can not provide you a real solution for this. You will need some sort of edit distance or something like that. As far as I know there is no operator that allows calculating string similiarities up to now...
<process version="5.1.008">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.008" expanded="true" name="Process">
<process expanded="true" height="145" width="279">
<operator activated="true" class="generate_nominal_data" compatibility="5.1.008" expanded="true" height="60" name="Generate Nominal Data" width="90" x="45" y="30">
<parameter key="number_of_attributes" value="2"/>
<parameter key="number_of_values" value="3"/>
</operator>
<operator activated="true" class="generate_attributes" compatibility="5.1.008" expanded="true" height="76" name="Generate Attributes" width="90" x="179" y="30">
<list key="function_descriptions">
<parameter key="att1_equals_att2" value="if(att1 == att2, "true", "false")"/>
</list>
</operator>
<connect from_op="Generate Nominal Data" from_port="output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/>
</process>
</operator>
</process>
Regards
Matthias
Hi Matthias,
thank you for your help. i have tried, but it is not unfortunately what I want to see as result
therfore I write you my Problem exactly.
I have two table VGA and post joint (innen) together. now I want to compare two column address in Post with address in VGA, so I can find out which address has changed and the results in column results as "yes"or " no" save. is it possible in Rapid Miner? ???
Best Regards
Best Regards
this operator compares ROC charts for models as the operator description says:
Generates a ROC chart for the models created by each of the inner learners and plot all charts in the same plotter.
This will not help you when simply comparing two columns. What tests do you want to apply to the columns? If you can express them with some functions and expressions (if-then-else for example) I would suggest to consider the "Generate Attributes" operator. You can define different values for the outcome of the comparison. Please read the comprehensive operator description for details. If you need further help, please post some details regarding the intended comparison (what shall be compared and what shall happen as result).
Regards
Matthias
