Rapidminer is too slow on Fedora 13
Hello,
I am using Rapidminer at the University on a Windows XP PC. On this Machine the software ist pretty fast. I think it is a dual core with 4 GB RAM or something like that hardware.
At home I try to use Rapidminer too, but is damned slow on my Machine. (It is a Core i5 with 8 GB RAM not so pretty old, or?) I run it on a Fedora 13. I have found this:
http://rapid-i.com/rapidforum/index.php/topic,2298.msg9093.html#msg9093 but this hint doesn't help me. I have try openJDK and the SUN JDK. But on both it is too slow. What is the mistake?
greetings carsten
greetings carsten
1 - 2 of
21
I have found the reason for my Problem. It is the nvidia driver. see here the post from 05-21-11, 04:31 PM is like my rapidminer, some icons but no text http://www.nvnews.net/vbulletin/showthread.php?t=156264&page=2
Now I try a old nvidia driver. ???
this sounds like an issue with java and linux. There is no platform specific code in RapidMiner, so no problem there.
You might want to google a bit, my first query came up with this, maybe it will help?
HowTo: extremely speed up slow Java apps by enabling them to use OpenGL
Otherwise I'm afraid you'll have to google a bit yourself about the issue of slow java apps on linux. (google finds millions of hits for the problem, seems to be not that uncommen
Regards,
Marco
