Select by Random
User: "MuehliMan"
New Altair Community Member
Updated by Jocelyn
Hello RM community,
I encountered a strange problem with the operator "Seleect by Random". I use it to select 1 attribute out of a set of various. I want to randomly select 1 attribute and process it. So I set the number of attributes to 1 and check "Use local random seed". I use Loop Parameter to iteratively change the local random seed.
Strangely, always the same attribute is selected. How can I manage to make RM select 1 RANDOM attribute in a loop?
I can provide an example code if needed.
Cheers,
Markus
