Hi, I have used the operator"process documents from data". But it shows "Mandatory input missing at port Process Documents from Data.document 1". Then I add three operators in the superoperater, it doesn't work. Thx for your help!
well, you did not seem to define all connections in a correct way. Here is a simple example process: Cheers,
Ingo
