Hi, I haven't been using Hypermesh that long.
How can I fix error 760? I once attached the rad and out file.
I hope you can help me.
Thank you very much in advance!
Hello, looking at the *.out file, it gives a warning that there is no Defined Part in the model. I'm not an expert in Radioss, however, you may get more of a response in the Radioss Forum... One would hope this is an easy fix
Hello, yes this was the Problem. Thanks!
