Using SQLServer driver
Does anyone have experience setting up a SQLServer JDBC driver in RM 5.1?
Here's what I've already done:
-installed SQLServer JDBC drivers
-installed new driver in RM (Tools->Manage Database Drivers)
-setup a DB connection (Tools->Manage Database Connections)
I'm running SQLServer Express. My connection details looks like this:
Database system : SQLServer (my driver that I'd previously installed)
Host: localhost/sqlexpress
Port: 1433
Database schema:
User: <username>
Password: <password>
URL shows up on the UI as : jdbc:sqlserver://localhost/sqlexpress:1433
When I hit the 'Test' button, I get the following (partial) message:
The TCP/IP connection to the host localhost/sqlexpress, port 1433 has failed. Error: "null. Verify t...
The rest of the message is not visible in the UI. SQLServer browser service is up. TCP is enabled.
Any help is appreciated! Thanks!
Port: 1433
Database schema:
User: <username>
1 - 7 of
71
Hello, I am facing the same problem you resolve , I can not connect to SQL Server express 2010, the connection dialog fiedls were filled with localhost/SQLEXPRESS with port or without, I have integrated security, I tried to add the string integratedsecurity=true in the field database schema and even so the connection fail, any idea. thanks
I have tried again to test the connection, now I have a network error ioexception message.
According to database drivers there is a sql server driver already installed, i am working with 5.3 version of rapidminer, and windows 7, sql server is authenticated qith windows. Any idea.
The Sourcefourge download (jtds-1.3.0-dist.zip) comes with a 64 bit version and a 32 bit version of ntmlauth.dll, each in its own subdirectory. Note that the 64 bit DDL in \jtds-1.3.0-dist.zip\x64\SSO must be copied to the C:\Windows\System32[!] directory and the 32 bit DDL in \jtds-1.3.0-dist.zip\x86\SSO must be copied to C:\Windows\SysWOW64[!]. (The names of the Windows system subdirectories are rather confusing, cf. http://en.wikipedia.org/wiki/WoW64). ;
Hope this helps
Roland
Hope this helps
Roland
jdbc:sqlserver://MYSERVER\MYINSTANCE;integratedSecurity=true
Based on that, and assuming that you aren't using integrated security, I'd suggest trying one of the following two URL's:
jdbc:sqlserver://localhost\sqlexpress
jdbc:sqlserver://localhost\sqlexpress:1433
Hope that helps.
Keith
