Memory issue in LOFOutlierDetection operator
Hi,
I have a data with 4615 observations and I am applying ' LOFOutlierDetection' on this data. But doing this, I get the error, "OutOfMemoryError Caught: Java heap space". Below i paste the code:
How can I tackle this memory issue?
Details of my system:
2.79 GHz, 0.99GB of RAM.... I can increase my RAM size to 2GB too, but again the problem persists.
Thanks in advance,
Shubha.
<operator name="Root" class="Process" expanded="yes">I tried to increase the allocated memory in 'RapidMinerGUI.bat' (MAX_JAVA_MEMORY), but this was not useful.
<operator name="CSVExampleSource" class="CSVExampleSource">
<parameter key="filename" value="E:\Inputs\Datafile.csv"/>
</operator>
<operator name="LOFOutlierDetection" class="LOFOutlierDetection">
<parameter key="minimal_points_lower_bound" value="3"/>
<parameter key="minimal_points_upper_bound" value="3"/>
</operator>
</operator>
Thanks in advance,
Shubha.
1 - 1 of
11
Using outlier detection operators working with inter-object distances is a memory intensive job, especially for datasets with lots of observations. For your dataset you may need up to 1.5G or even 2G of main memory exclusivly available to RapidMiner to perform the LOF outlier detection. Have a look at the SystemMonitor view in RapidMiner to check the amount of main memory assigned to the program.
Greetings,
Helge
