"CSV Import Date-Time formatting problem"
User: "hughesfleming"
New Altair Community Member
Updated by Jocelyn
Hi,
I have a question about how to format time when I import a csv consisting of  intraday forex data. I have duplicated the neuralmarket trends tutorial 10 using forex data exported from metatrader. Everything works for daily data when I import using yyyy-MM-dd and deselect time. Now I am trying to import four hour data with date,time,input,input,input,input as the header but when I format time as hh:mm:ss I get an error. Also at this point is there a way to combine date and time into one column and assign an id to that combination? I have looked at the documentation with regards to formatting date and time in java but I can't seem to get this to work.
Many thanks,
Alex
