Problem with importing RapidMiner's workflow from myexperiment
Hello!
Every time I try to load RapidMiner's workflow which I download from myexperiment site, I receive an error:
This is workflow I try to load: http://www.myexperiment.org/workflows/1972.html
Moreover this file doesn't seem to be valid XML file....
Error while loading [...]I receive the same error when I try to load the same workflow via myexperiment plugin.
Reason: Content is not allowed in prolog.
1 - 1 of
11
thanks for the report, there seem to be some problems with the encoding. We will take a look at that.
Greetings,
Sebastian
