Altair RISE
Nominate Yourself Now!
hm toolbars
User: "tinh"
Altair Community Member
Updated by tinh
Hi all.
i made some hypermesh macros in form of 'toolbar'
if you feel it interesting, please send me your mcid  image/emoticons/default_wink.png' alt=';)' srcset='/emoticons/wink@2x.png 2x' width='20' height='20'>
1 - 27 of 271
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    Congratulations,it really looks so interesting  image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    Altair Employee
    Interesting! But if you could share us how to do that, it's even more interesting image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    User: "tinh"
    OP
    Updated by tinh
    Interesting! But if you could share us how to do that, it's even more interesting image/emoticons/default_smile.png' alt=':)' srcset='<fileStore.core_Emoticons>/emoticons/smile@2x.png 2x' width='20' height='20'>
    Hiii Mr.Quy
    to measure (diameter, surf-surf distance, ...) => click on corresponding toolbar buttons
    pick a circle => it shows diameter and radius
    pick 2 surfs => it shows distance
    pick a surf then a line => it shows distance,
    i add options to measure distance at closest position or picking position (ex. if in case 2 surfs or surf-line are not parallel)
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-93804400-1416965578_thumb.pn
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-01474400-1416965589_thumb.pn
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-17153100-1416965595_thumb.pn
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-54457600-1416965597_thumb.pn
    Altair Employee
    No, I'm speaking about ...  TCL script, not its usage image/emoticons/default_wink.png' alt=';)' srcset='/emoticons/wink@2x.png 2x' width='20' height='20'>
    User: "tinh"
    OP
    Updated by tinh
    image/emoticons/default_biggrin.png' alt=':D' srcset='/emoticons/biggrin@2x.png 2x' width='20' height='20'> it's a secret!
    i'll give a brief explain (actually difficult to explain fully in english, i am sorry)
    - diameter measure: i used only command hm_getbestcircle, it return diameter value directly just in one click
    - surf-surf measure: when click on surf, it creates a node at clicking position, the node then projected to alternative surf, projecting direction is not normal to the surf but make equally angle with each surf (so in case 2 surfs not parallel then => get correct distance)
    - surf-line measure: similar to surf-surf, but temp node will be created on line, it then projected normally to surf (to find normal distance) and hm_getdistancefromnearest on surf to get true distance
    - line-line measure: similar to surf-surf, but after temp node created on a line, a closest position from it on the alternative line will be get (hm_getdistancefromnearest)
    - segment-segment (used when measuring height of a bead): i do some vector operations to find common perpendicular line of the two segment, length of it is distance between 2 segments, with option 'extended closest postion' then this value is reported, in case of 'closest position' it is compared to relative position between 2 segments ( as edge-to-edge contact calculation)
    Altair Employee
    Thank you!
    I'm looking for a sample code to create a customized toolbar like yours. I searched within HM's documents but I found nothing for this moment image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    User: "tinh"
    OP
    Updated by tinh
    Hii Mr.Quy
    below is code to make my toolbar
    actually create toolbar can be done as in 'hmsettings.tcl' file. but i modify something to fix errors when starting hm or first invoking to the functions
    image/emoticons/default_cool.png' alt='B)'>
    proc ::nvtb:_DestroyToolBar {ToolBarName} {
    if {[winfo exists ._ViviToolBar-$ToolBarName]} {
    destroy ._ViviToolBar-$ToolBarName
    foreach window [winfo children .] {
    if {[string match *.minibartoplevel* $window]} {
    foreach window2 [winfo children $window] {
    if {[string match *ViviToolBar-$ToolBarName* $window2]} {
    destroy $window
    break
    proc ::nvtb:_CreateMeasurementToolBar {} {
    ::HM_Framework:_CreateMinibar . ViviToolBar-Measurement HyperMesh:HyperMesh:_blank
    ::HM_Framework:_SetMinibarIconList ViviToolBar-Measurement [list \
    [list [list p_CreateMinibarIcon [file join $::nvtb::v_ImageDir MeasureCircleDiameter-24.png ] 'if {!\[namespace exists ::nvtb\]} {source \'$::nvtb::v_InfoScript\'; ::nvtb:_MeasureCircleDiameter } else {::nvtb:_MeasureCircleDiameter }' {Circle Diameter} 1] ] \
    [list [list p_CreateMinibarIcon [file join $::nvtb::v_ImageDir MeasureDistanceSurfSurf-24.png ] 'if {!\[namespace exists ::nvtb\]} {source \'$::nvtb::v_InfoScript\'; ::nvtb:_MeasureDistanceSurfSurf } else {::nvtb:_MeasureDistanceSurfSurf }' {Surf-Surf Distance} 1] ] \
    [list [list p_CreateMinibarIcon [file join $::nvtb::v_ImageDir MeasureDistanceSurfLine-24.png ] 'if {!\[namespace exists ::nvtb\]} {source \'$::nvtb::v_InfoScript\'; ::nvtb:_MeasureDistanceSurfLine } else {::nvtb:_MeasureDistanceSurfLine }' {Surf-Line Distance} 1] ] \
    [list [list p_CreateMinibarIcon [file join $::nvtb::v_ImageDir MeasureDistanceLineLine-24.png ] 'if {!\[namespace exists ::nvtb\]} {source \'$::nvtb::v_InfoScript\'; ::nvtb:_MeasureDistanceLineLine } else {::nvtb:_MeasureDistanceLineLine }' {Line-Line Distance} 1] ] \
    [list [list p_CreateMinibarIcon [file join $::nvtb::v_ImageDir MeasureDistanceSegmSegm-24.png ] 'if {!\[namespace exists ::nvtb\]} {source \'$::nvtb::v_InfoScript\'; ::nvtb:_MeasureDistanceSegmSegm } else {::nvtb:_MeasureDistanceSegmSegm }' {Segment-Segment Distance} 1] ] \
    [list [list p_CreateMinibarIcon options-24.png 'if {!\[namespace exists ::nvtb\]} {source \'$::nvtb::v_InfoScript\'; ::nvtb:_Options } else {::nvtb:_Options }' {Options} 1 ] ] \
    ::HM_Framework:_AddMinibarToDockframe ViviToolBar-Measurement .mainFrame.dockframe_top
    set ::HM_Framework::Minibar::ViviToolBar-Measurement:_status 1
    proc ::nvtb:_CreatePullDownMenuForToolBar {ToolBarName} {
    #set menu [. cget -menu].view.toolbars
    set menu [hm_framework getpulldowns].view.toolbars
    if {[catch {$menu index ViviToolBar-${ToolBarName}}]} {
    $menu add checkbutton \
    -indicatoron 1 \
    -offvalue 0 \
    -onvalue 1 \
    -variable ::HM_Framework::Minibar::ViviToolBar-${ToolBarName}:_status \
    -command '::HM_Framework:_ToggleMinibar ViviToolBar-${ToolBarName}' \
    -label ViviToolBar-${ToolBarName} \
    -underline 0
    return 0
    } else {
    return 1
    Altair Employee
    Hi tinh,
    Thank you so much for sharing it with us image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    Altair Employee
    Thank you so much Tinh!
    Altair Employee
    Hi.. Would you please send me the code.. suresh.babuks@gmail.com
    Altair Employee
    Thanks for sharing.. Is this the complete code??
    User: "tinh"
    OP
    Updated by tinh
    Hi, below is complete code, after some persons used, i fix some bugs
    now already 4 persons use it  image/emoticons/default_biggrin.png' alt=':D' srcset='/emoticons/biggrin@2x.png 2x' width='20' height='20'>
    If you like, please send me your MCID, i just want to record number of users
    Altair Employee
    Hi tinh,
    What is the MCID?
    and when i try to run this script it is also saying 'COULD NOT VERIFY MCID'.
    What should i do?
    Reg
    Karthi
    User: "tinh"
    OP
    Updated by tinh
    Hi tinh,
    What is the MCID?
    What should i do?
    Reg
    Karthi
    Really? Could you try again with this new updated:
    Altair Employee
    I tried with the updated one also..
    It is also coming same
    Unexpected Error
    Could not verify your MCID. Please contact to tinh411@gmail.com
    User: "tinh"
    OP
    Updated by tinh
    Hi all
    this second toolbar has auto-detect mesh features and help fast create some element patterns with less picking
    :D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' width='20'>
    User: "tinh"
    OP
    Updated by tinh
    Hi all
    i finished set of 3 toolbars. Hope new hypermesh version will have new nicelooking ones  B)/emoticons/default_cool.png'>
    <?xml version="1.0" encoding="UTF-8"?>post-3195-0-69576900-1421398963_thumb.pn
    Altair Employee
    It is throwing Error while executing this  script in Hyperworks 12.0
    Can you please help me on this .I am trying to call the tcl file which was provided in the zip file
    Regards
    sri
    User: "tinh"
    OP
    Updated by tinh
    Regards
    sri
    Hi,
    could you please inform me what error occurred?
    input below command at command window to know detail
    set errorInfo
    Altair Employee
     can you please share the macro as tcl file
    Altair Employee
    #created
    #varthamanan
    proc CreateToolBar { carName jataList } {
        #Create Toolbar
        ::HM_Framework:image/emoticons/default_tongue.png' alt=':P' srcset='/emoticons/tongue@2x.png 2x' width='20' height='20'>_CreateMinibar . $carName;
        #Add Icon
        foreach Data $jataList {
            set iconfile [ lindex $Data 2 ]
            set cmd [ lindex $Data 1 ]
            set name [ lindex $Data 0 ]
            ::HM_Framework:image/emoticons/default_tongue.png' alt=':P' srcset='/emoticons/tongue@2x.png 2x' width='20' height='20'>_AddIconToMinibar $carName \
                             [ list p_CreateMinibarIcon [ file tail $iconfile ] $cmd $name 1 ];
        #Pack Toolbar
        ::HM_Framework:image/emoticons/default_tongue.png' alt=':P' srcset='/emoticons/tongue@2x.png 2x' width='20' height='20'>_AddMinibarToDockframe $carName .dockframe_center;
        #Destroy
    proc RedrawWindows { } {
        set pos [ hm_getcommandposition ]
        if { $pos == 'top' } {
            hm_setcommandposition bottom
            hm_setcommandposition top
        } else {
    set jataList ''
    # quick edit panel
    set EditIcon 'nodesInterpolateOnSurf-24.gif'
    set jataList '$jataList { {Quick Edit} { ::face {args} } $EditIcon }'
    # automesh panel
    set MeshIcon 'meshLines-32.gif'
    set jataList '$jataList { {AutoMesh} { hm_pushpanel \'automesh\' } $MeshIcon }'
    # check panel
    set CheckIcon 'check.gif'
    set jataList '$jataList { {Element Checks} { hm_pushpanel \'check elems\' } $CheckIcon }'
    # vis button
    set MeshIcon 'distanceBetweenNodes-24.gif'
    set jataList '$jataList { {Distance} { hm_pushpanel \'distance\' } $MeshIcon }'
    # vis button
    set MeshIcon 'edgesGeneral-24.gif'
    set jataList '$jataList { {Edges} { hm_pushpanel \'edges\' } $MeshIcon }'
    # vis button
    set MeshIcon 'elem-normal.gif'
    set jataList '$jataList { {Normals} { hm_pushpanel \'normals\' } $MeshIcon }'
    # vis button
    set MeshIcon 'intersectionGUI.gif'
    set jataList '$jataList { {intersection} { hm_pushpanel \'penetration\' } $MeshIcon }'
    # vis button
    set MeshIcon 'numbers-24.gif'
    set jataList '$jataList { {Numbers} { hm_pushpanel \'numbers\' } $MeshIcon }'
    # vis button
    set MeshIcon 'pan.gif'
    set jataList '$jataList { {Translate} { hm_pushpanel \'translate\' } $MeshIcon }'
    # vis button
    set MeshIcon 'pointsExtractParametric-24.gif'
    set jataList '$jataList { {Project} { hm_pushpanel \'project\' } $MeshIcon }'
    # vis button
    set MeshIcon 'blankNesting-24.gif'
    set jataList '$jataList { {Reflect} { hm_pushpanel \'reflect\' } $MeshIcon }'
    # vis button
    set MeshIcon 'gap-24.gif'
    set jataList '$jataList { {Replace} { hm_pushpanel \'replace\' } $MeshIcon }'
    # vis button
    set MeshIcon 'erase-16.gif'
    set jataList '$jataList { {Edit elements} { hm_pushpanel \'edit element\' } $MeshIcon }'
    # vis button
    set MeshIcon 'objectives.gif'
    set jataList '$jataList { {Replace} { hm_pushpanel \'split\' } $MeshIcon }'
    # vis button
    set MeshIcon 'linesExtractEdge-24.gif'
    set jataList '$jataList { {Smooth} { hm_pushpanel \'smooth\' } $MeshIcon }'
    # vis button
    set MeshIcon 'linesOffsetConstant-24.gif'
    set jataList '$jataList { {node edit} { hm_pushpanel \'node edit\' } $MeshIcon }'
    # vis button
    set MeshIcon 'post-shaded-16.gif'
    set jataList '$jataList { {node edit} { hm_pushpanel \'ruled\' } $MeshIcon }'
    # vis button
    set MeshIcon '3dElements-24.gif'
    set jataList '$jataList { {node edit} { hm_pushpanel \'drag\' } $MeshIcon }'
    # vis button
    set MeshIcon 'solidDragLine-24.gif'
    set jataList '$jataList { {node edit} { hm_pushpanel \'solid map\' } $MeshIcon }'
    # vis button
    set MeshIcon 'morphingVolume-16.gif'
    set jataList '$jataList { {node edit} { hm_pushpanel \'HyperMorph\' } $MeshIcon }'
    proc ::face {args} {
    *appendmark elements 1 'by adjacent'
    hm_saveusermark elems 1;
    *appendmark elements 1 'retrieve'
    hm_highlightmark elems 1 h;
    # create toolbar
    catch { ::HM_Framework:image/emoticons/default_tongue.png' alt=':P' srcset='/emoticons/tongue@2x.png 2x' width='20' height='20'>_DeleteMinibar CustomToolBar }
    CreateToolBar fanels $jataList
    # redraw window
    RedrawWindows
    Altair Employee
    #created
    #varthamanan
        #Create Toolbar
        #Add Icon
        #Pack Toolbar
        #Destroy
        } else {
    set jataList ''
    # quick edit panel
    # automesh panel
    # check panel
    # vis button
    # vis button
    # vis button
    # vis button
    # vis button
    # vis button
    # vis button
    # vis button
    # vis button
    # vis button
    # vis button
    # vis button
    # vis button
    # vis button
    # vis button
    # vis button
    # vis button
    # create toolbar
    # redraw window
    RedrawWindows
    Altair Employee
    this is my toolbar  created by most using command
    Altair Employee
    Hi tinh, could you please share this macro with me? It looks very interesting. Do you know if it works with hypermesh 2017?
    Thank you in advance
    User: "ravinder muppidi"
    Updated by ravinder muppidi
    Hi tinh,
    I am eagerly waiting for this toolbar script.
    User: "tinh"
    OP
    Updated by tinh
    Forget it! Hm2019 toolbars are really nice and convienience.
    Hello Tinh,
    I am really  happy for your response.
    Hm 2019 toolbars may be better but we still using old version like hm 14 and hm 17 as stable versions.
    Kindly share with us it will be more and more useful.  Rather than keeping them calm, we wanted to use it fully and efficiently.
    Hope you help us with your scripts.
    here my mail id to drop it  ravinderdme@gmail.com
    Thank you in advance!
