Do I need a dedicated license to use the Computing Distribution Manager?
User: "Ciro Alosa_21513"
Altair Community Member
Updated by Ciro Alosa_21513
Hi,
I am trying to connect other PCs to my PC for a distributed computing. I am using the CDE 2.3 of Flux, but I can't see the other PCs.
The number of distribution license token detected is: N/A.
Do I need a specific license to run the distributed computing?
Regards
1 - 5 of 51
    User: "fzidat"
    Altair Employee
    Updated by fzidat
    Hello Ciro;
    Before answering on the question, i would like to know If when you use CDE on your own machine, does it works ?
    Regards
    OP
    Hi Farid,
    if I select "multiple nodes" and set my PC as server the configuration goes well.
    The other PCs can't see the server by the way.
    User: "fzidat"
    Altair Employee
    Updated by fzidat
    Thank you Ciro!
    So, you need to have server licence.
    For the configuration of CDE, please have a look on the documentation available from Flux supervisor:
    OP
    Thank you very much Farid.
    Yes, we have a server license. Must the CDE run on the server where the license is?
    In a multiple nodes configuration, the server must be the same as the server license? Or I can setup any of the PCs connected to the server license to act as the server for the CDE?
    I'm sorry, but this thing is a bit confusing.
    User: "fzidat"
    Altair Employee
    Updated by fzidat
    You are welcome Ciro!
    The main important thing, is that flux should be installed in each node of this cluster, and each node must refer to the right licence server.
    I hope this will help you.
    Regards
