Altair RISE
Nominate Yourself Now!
Select Attributes Not Poulating Attribute List
User: "dragoljub"
New Altair Community Member
Updated by Jocelyn
Hi Guys,
I am running into a strange problem with the select attributes operator. In many cases with a complex process select attributes simply does not see the meta data passed from other operators (read csv in a loop etc...). I have tried validating the process enabling syncing of meta data for each step in the process etc. Nothing seems to work.
To get around this I am forced to save the example set in the repository right before my select attributes operator is executed, then use a second process to select attributes from the data saved in the repository, then copy the selected attributes operator back into the original process to select the subset of attributes I want.
How can we solve this issue?  ???
Thanks,
-Gagi
