I need to use Monarch v14 with the command line utility to open a report and a model without exporting; just stay open.
If I use the command line to start Monarch, open a report and model without specifying any other parameters such as export; Monarch will not open the report and model.
Using an older version of Monarch with the command line utility I was able to start Monarch, open a report and model and it stayed open so that I could make changes to the model then I could export and save the model with the new changes.
Any ideas?
